Polyiso Insulation Boards - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-16-2010, 10:04 PM   #1
polyiso insulation boards
I want to use foil face, 2 inch thick polyiso for wall insulation. What tool cuts it the best?
davede is offline   Reply With Quote
Old 05-16-2010, 11:02 PM   #2
Totally screwed together
Depends.
If you are making a couple of cuts, I like to use one of those snap off style disposable blades that you can extend about 3" when new.
If you are making LOTS of cuts, like cutting them down so the fit between stud/rafter bays, then use a table saw.
xxPaulCPxx is offline   Reply With Quote
Old 05-17-2010, 05:33 AM   #3
I am cutting 2" myself now- no foil, but i am using a circular saw with a paneling blade installed backwards.
chaos232 is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
super insulation retrofit with rigid insulation hostaking Building & Construction 5 01-07-2009 10:23 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
