Polycarbonate Sheets - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-03-2008, 04:57 PM   #1
Rewards Points: 150
polycarbonate sheets
Hi all,
I'm planning to put a roof over my deck, this will consist of five sheets of 8ml polycarbonate. Each sheet is 4'x18'.
My Question is, the only connector the distributor could get me is the "H" profile not the base and cap system.(the base and cap is just like the H except you can put down the bottom half, then your sheet, then snap the top half on)
My question is, anyone know how tough it will be to join these sized sheets with the H profile? Can you tap in the sheet from the side or do you need to slide it on from one end? Any recommended lubricant?
I would accept any and all practical advice. Thanks
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 10-03-2008, 11:38 PM   #2
Advice worth 2 cents!
Rewards Points: 150
Sounds to me like your talking to the wrong folks. Get in touch with the manufacturer and buy the proper parts as the original design calls for.
HandyPete is offline   Reply With Quote
Old 10-05-2008, 06:08 PM   #3
Custom Deck Builder
BuiltByMAC's Avatar
You're talking about 8 mil thick double wall polycarbonate panels - PalRam SunLite or similar product.
You WILL NEED the Snap H channel to successfully install those panels. The reg. H channel is too tight to slide up 18' and you'll damage the panels trying to beat it in from the side.
Find another distributor.
BuiltByMAC is offline   Reply With Quote
What do you think about Double Glazing with plastic sheets? foster01 General DIY Discussions 1 08-25-2008 04:12 PM
how much Drywall to use??? Tdoggy187 Carpentry 34 03-11-2008 09:10 PM
question about those 'fabric' sheets you put under mulch in landscape beds joeyboy Landscaping & Lawn Care 14 08-01-2007 10:32 PM
Drywall instead of plaster? shofnerd Remodeling 5 06-23-2007 09:02 AM
sheets of quantity sfalzon Carpentry 1 07-22-2006 10:48 AM
