Poly Over Insulation? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-11-2009, 09:21 AM   #16
Ok guys not sure how this works, seems as though some of you are responding to each other?????
We installed pine t&g on the valted ceiling and will be installing pine log siding on the walls but have not done so yet.
jane-diy is offline   Reply With Quote
Old 12-11-2009, 09:28 AM   #17
ccarlisle's Avatar
Sure, most of us have opinions that don't mesh necessarily with each other, so that's normal. I just wish people would contribute more than one-word answers to what is a complex subject, or would read carefully what the OP has already done, In this case, I had a good idea you were into t&g pine, so where's the drywall that someone referred to? search me...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 12-11-2009, 01:42 PM   #18
home builder
Originally Posted by ArmchairDIY View Post
If I understand correctly your question is: With both poly and the kraft facing creating essentially a double vapor barrier will you have problems.
Kraft facing and poly combined is not the recommend vapor barrier system, it's one or the other. But if you already have the T&G installed I would not worry to much if your ceiling is properly vented and insulated.
yup, you just made a diaper. lol trapping the moisture in between the 2 vapor barriers
kubie is offline   Reply With Quote
Old 12-11-2009, 01:54 PM   #19
MJW
Kraft paper isn't much of a vapor barrier. It works in warmer climates, but in colder areas with more possible moisture, you need the poly.
MJW is offline   Reply With Quote
Tags
insulation , moisture barrier , poly
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 09:57 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
