Pole Building Roof Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-11-2010, 06:53 PM   #1
Pole building roof insulation
I am at odds with the way I should add insulation to the roof of my metal pole building. The roof already has the very thin backed insulation that you see in metal buildings. I use my attic and I want to insulate between the joist bays but have heard of moisture problems when adding backed insulation to the existing thin backed insulation. I want to keep the existing backed insulation were its at. Is it best to add unbacked insulation or is there another product that I am unaware that wont cause mositure problems?
bmdibble is offline   Reply With Quote
Old 11-11-2010, 08:14 PM   #2
joed's Avatar
Rewards Points: 12,438
Spray foam and drywall covering or fire rated spray on covering.
Old 11-12-2010, 12:19 AM   #3
Rewards Points: 1,092
Closed-cell spray foam may indeed be your answer. If you do decide to use batts somehow, I would sure make sure there is plenty of ventilation between the batts and the roofing. And don't waste time w/ fiberglass. My 2 cents.
Tags
attic , insulation , pole building
Blown Insulation - Flat roof AndrewF Roofing/Siding 1 12-31-2009 06:41 PM
Building a Porch Roof Engus Building & Construction 1 04-06-2009 08:43 PM
Building a Pole Garage myself, got a few ?'s jk333 Building & Construction 4 10-16-2008 01:41 PM
Building Roof over Roof, changing pitch Thomas O Roofing/Siding 7 03-05-2008 09:51 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
