Pole Building Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-05-2007, 02:53 AM   #1
I recently built a pole building. I used the 6' wide fiberglass/vinyl insulation on the roof under the metal. I want to heat a portion of this building year round and need to increase the R-value. Should I use fiberglass insulation between the roof purlins or a reflective insulation (foil/bubble) hung from them or both. Live in Spokane, WA. Thanks.
70RANGER is offline   Reply With Quote
Old 02-05-2007, 07:02 PM   #2
Construction Guru
Pole building insulation
The fiberglass insulation should have a decent rating. You have two easy options though, use rigid insulation between the purlins like you spoke of or build a ceiling down lower to reduce the cubic feet that you are trying to condition.
sheeter is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
pole barn building costs? THEBIGPUNN Building & Construction 1 08-04-2007 05:29 AM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 02:11 AM
steel building insulation problem rjf Building & Construction 17 02-09-2007 06:24 AM
Insulation for a metal building amy General DIY Discussions 2 04-30-2006 09:57 PM
