Pole Building Footings - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-26-2010, 05:44 PM   #1
Pole Building footings
I'm having pioneer pole buildings put up a 24x30 pole building. Today they came and drilled the footings. The 5 or six holes in the front of the building all have soupy mud and water in them, does anyone know if this will create a problem when they instal the concrete pill in hole with the post on top. Will this let the front of the building sink? What can be done to keep this from happening or should i wait till things dry out?
Corby is offline   Reply With Quote
Old 02-27-2010, 07:43 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Ayuh,... As long as they're below the frost line, it shouldn't matter in the least..
Old 02-27-2010, 07:59 AM   #3
hole needs to be clean and empty
The older I get the better I was
Old 02-27-2010, 12:18 PM   #4
World's Tallest Midget
Mort's Avatar
Rewards Points: 692
I wonder if sticking some Sonotubes in there would help. Or would you want the concrete to spread out a bit more?
I hate signatures.
Mort is offline   Reply With Quote
Building a pole barn, need help rmbanas Building & Construction 22 11-04-2012 03:37 PM
Building a temporary workshop inside of large pole building HandyDave Building & Construction 0 02-17-2010 08:39 PM
setting posts for pole building 2wheelerbill General DIY Discussions 2 04-12-2009 07:13 PM
Building a Pole Garage myself, got a few ?'s jk333 Building & Construction 4 10-16-2008 01:41 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 02:11 AM
