Pole Building Construction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-18-2011, 08:58 AM   #1
pole building construction
Building a pole garage and just finished setting trust.30x48x12. My question is to how far to run my fascia board out on the sides to meet the fascia for and overhang on the gable end? Trying to figure the distance so I wont have to cut the soffit. Any suggestions is appreciated
logs is offline   Reply With Quote
Old 04-18-2011, 09:03 AM   #2
waterman1971's Avatar
Rewards Points: 154
Let it run wild until you are ready to run the soffit. If all else fails, hold the soffit up there and make a mark.
waterman1971 is offline   Reply With Quote
Old 04-18-2011, 09:08 AM   #3
Wont I need to put fascia board on first before I put down the metal roof so I know where to start and stop roofing?
Double pole breaker used as single pole WonderingOne Electrical 11 11-30-2010 12:37 AM
New construction on existing steel building burton Building & Construction 6 03-30-2010 03:22 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
NEC uses building size?????? hhiibel Electrical 14 08-08-2008 12:19 PM
