Old 10-28-2011, 12:16 AM   #1
pole barns
can i build barn by setting post on piers instead of digging holes for post
willie jones is offline   Reply With Quote
Old 10-28-2011, 07:24 AM   #2
pole barns
Depends on local code, but probably. That is the better method, anyhow. Anything buried in dirt will deteriorate faster, especially wood. This method usually requires more bracing.
Old 10-28-2011, 01:47 PM   #3
Tileguy
Bud Cline's Avatar
pole barns
This should prove to be interesting!
Old 10-28-2011, 02:25 PM   #4
pole barns
When we were building our pole barn we found out that the planned back side was sitting on solid rock a few inches below the ground. The only option was to chisel out enough of the rock at each support to pour about a cubic foot of concrete into each, then sank J bolts into the concrete to fasten onto a Simpson Strongtie post base. There are other post bases that might work better, like these:
http://strongtie.com/ftp/catalogs/c-2011/C-2011-p062.pdf
BTW, one bolt turned out to be too far out of line, but there was still hope. We drilled a new hole and used epoxy with a straight bolt for that one:
http://strongtie.com/ftp/catalogs/c-2011/C-2011-p060.pdf
All other supports could be sunk into the ground. Our building was only 24X14 and one story high, though.
They have extensive strength and resistance charts on their website. You might check them to see if the specs are sufficient for your barn.
NancyNGA is offline   Reply With Quote
Single Pole vs. Double Pole Thermostat dforeid Electrical 14 08-26-2012 09:12 AM
Can a Square D 4 pole circuit breaker be used as a 2 pole circuit breaker. TifcoJim Electrical 3 08-24-2011 12:59 AM
Double pole breaker used as single pole WonderingOne Electrical 11 11-30-2010 01:37 AM
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 12:21 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
