Pole Barn Truss Braces - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-19-2014, 08:14 PM   #1
Rewards Points: 89
Pole barn truss braces
My 30x40 pole barn was already on the property when I bought it and I'm wondering about these 2x6 braces as shown in the link below. Unless I'm looking at them wrong I can't imagine they are transferring load to the post from the truss so I'm guessing they are only there to keep the truss sitting on the notch. They are located on every post. This makes me wonder if they were added after the fact.
If these are not carrying load to the post, would they be better off bolted through or replaced with clips?
https://drive.google.com/file/d/0B0A...it?usp=sharing
rich_kildow is offline   Reply With Quote
Old 01-19-2014, 08:29 PM   #2
Rewards Points: 13,960
That's some real funky framing you have there.
Looks like a poor way to help stop the building from racking and to also help with wind up lift.
I would have built it more like this.
http://www.bing.com/images/search?q=...lectedIndex=40
It does look like they where add after the fact. They should have cut at an angle on the ends and through bolted.
Old 01-19-2014, 09:18 PM   #3
Framing Contractor
Rewards Points: 120
We recently built a 30x40 pole barn and were told that detail is now code here (Ohio). I could see it on a barn with metal siding and/or roofing, but ours was completely sheathed. Code says they need to be at least a 2x6 on every post.
sixeightten is offline   Reply With Quote
Old 01-21-2014, 08:55 PM   #4
Rewards Points: 89
It does have metal siding and roof. So it sounds like it might be code but looks funky, which is enough for me to not mess with it.
Old 01-21-2014, 11:53 PM   #5
I can't get the picture to load
PoleBarnsNY is offline   Reply With Quote
Alternative to concrete for pole barn construction reteng Building & Construction 2 12-17-2013 03:51 AM
Vapor barrier for a Pole Barn maddog1 Building & Construction 3 08-22-2012 10:18 AM
400 amp service pole barn and home later walt1955 Electrical 2 06-29-2012 09:08 AM
Can you raise the roof on a pole barn after it's built? LMPD Building & Construction 12 03-24-2012 10:06 AM
Horse Barn Wiring - Pole Barn hagler Electrical 5 03-02-2012 10:23 PM
