Pole Barn ? @ Span Length & Size Lumber Req.. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-10-2008, 06:32 PM   #1
Rewards Points: 274
pole barn ? @ span length & size lumber req..
I will be building an enclosed 24'x36' pole barn and pulling permit to do so. Here is a link to the barn plan I will be building http://www.rodeobarns.com/s3624.html I plan on using 6"x6" treated posts set in concrete and spaced 12' apart on exterior and interior walls. My question is: Since there will be no walls supporting these, Do I need to run 2-LVL beams on all of these spans or can I get by with less, code-wise? I had to run these on my garage door headers because of the length of span. Some of the interior spans will be supporting ceiling joists and there will be a loft. Also, what size ceiling joists would i need to span 12'? Thanks.
ugabulldog is offline   Reply With Quote
Old 09-11-2008, 12:43 PM   #2
Do you plan on using the upstairs?......If so.....if it were mine, I would place the 6x6 post every 6'....I probably would place them 6' apart even if I was not going to use the upstairs.
Bpawb is offline   Reply With Quote
Old 09-11-2008, 01:53 PM   #3
Rewards Points: 274
I spoke with an engineer about what will be required, lots of LVL beams and $$$. I am thinking of going 20'x 30' with 10' OC.....
Old 09-11-2008, 02:07 PM   #4
Registered User
Termite's Avatar
Smart move bulldog!
Pole Barn johns Building & Construction 3 01-27-2008 02:56 PM
Pole Barn Girts, etc... DonAK Carpentry 1 08-16-2007 10:06 PM
pole barn building costs? THEBIGPUNN Building & Construction 1 08-04-2007 06:29 AM
Pole barn slab on a budget zubin6220 Building & Construction 3 06-17-2007 07:23 AM
Wiring a Pole Barn rocky Electrical 8 02-02-2006 07:34 PM
