Pole Barn No Walls Just Roof 24X36 - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-21-2009, 07:18 PM   #1
Resin Sniffer
nrgeek's Avatar
Pole barn no walls just roof 24X36
Im wanting to build a carport type pole barn, for a boat, this size 24 wide x 36 long, 10ft high ceiling with a low pitch as possible , I live in South East Tn .. in a rural area, we may have 10-15 inches of snow every 25 -40 years generally we see less than one inch a year total.
I obviously don't want any center poles .. cant put boat in there with poles in center .. How far should I place the 4x4s to support the roof apart and what width of trusses do I need to cover a 24 foot span ? with a over hang for water run off ? Will have a metal roof too.
Im eventually going to come back in and add metals walls with metal stud framing, time are tuff can only do one thing at a time.
Any body know of a plan that has such a building , every thing I find is much more complcated than I need or want .. just a roof and posts nothing else.
Thanx in advance
Sean
nrgeek is offline   Reply With Quote
Old 02-21-2009, 07:45 PM   #2
the Musigician
DangerMouse's Avatar
at least 24 feet! lol
seriously, have the trusses premade for you and delivered, easier than making them yourself, and they'll be the correct ones for the width you want.
4x4 posts? hmmmm
DM
Old 02-21-2009, 07:50 PM   #3
the Musigician
for something this large, i'd use 6x6s every 8' and lvls.
DM
Old 02-21-2009, 08:37 PM   #4
Resin Sniffer
nrgeek's Avatar
DM
what is lvls ?
Old 02-21-2009, 09:01 PM   #5
the Musigician
laminated veneer lumber. (approx. 2"x12") i'd use that to support your engineered trusses (with 1 or 2 foot overhang) 2 3/4" bolts in each post, oversized washers if you split. you may not get a lot of snow weight, but just the deck and shingles weighs a ton....
DM
Old 02-21-2009, 10:44 PM   #6
Tom Struble's Avatar
Rewards Points: 2,002
another thing to consider is wind uplift
Tom Struble is offline   Reply With Quote
Old 02-22-2009, 07:04 AM   #7
Resin Sniffer
nrgeek's Avatar
DM
Not using shingles, no decking , will have metal roof , and had planed on using 4x4 posts spaced every 6ft with 2x10 around tops of the 4x4 bolted to each post, and 2x6 around the bottom
Then attaching trusses to that, this will be enclosed later in the year, just trying to get a roof on now..
I have a flat roofed free standing car port ( well its was a hay shed) , that has a slanted flat roof that has been there for 50+ years and this would be better built than that is.
Heck metal car ports aint made no where near that good, and they hold to anything weather we have here.
Old 02-22-2009, 07:11 AM   #8
the Musigician
ok, i've not seen too many carports that large, so maybe others here can help. i'm not an engineer, but some here may be and can help you size your lumber to support what you need.
DM
Old 02-22-2009, 09:10 AM   #9
well its your boat
Old 02-22-2009, 09:37 AM   #10
the Musigician
Originally Posted by strublesiding@optonline.n View Post
well, its your boat
ahyup... i wouldn't trust my boat in it.
DM
Old 02-22-2009, 09:51 AM   #11
Rewards Points: 562
Some pitch would be cheapest part of the job. like at least 4/12. when you DO have snow,let it run or slide off. Meanwhile the leaks will be ALOT less!!
4just1don is offline   Reply With Quote
Old 02-22-2009, 09:57 AM   #12
the Musigician
metal car ports hold up to any weather we have here.
unless you already have all the materials, why not use one of these? they are engineered to do what you want, and easily sided later. Po)
DM
Old 02-25-2009, 12:15 PM   #13
My 20x55 barn is built with 4x4 untreated posts 9 foot ceilings. They are spaced 8 foot apart. This barn is really under built but it has been standing since 1987. We get some strong wind storms and lot of snow. I need to replace some of the posts now because of rot. I wish they would have used treated posts.
They used trusses so there is no beam running down the center. You will be best off using trusses. If you live in one of those places where they require you to get permits you will have to get your plan pre approved.
You might see if your local lumber yard has any plans or pole sizing charts.
mountainmike is offline   Reply With Quote
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 06:06 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
pole barn ugabulldog Project Showcase 2 01-13-2009 11:53 AM
Tile+Asphalt Roll Roof leaking - Opinion on what to do brookbphx Roofing/Siding 5 01-06-2009 06:51 AM
Addition and Roof Replacement lebeld Roofing/Siding 4 01-04-2009 06:11 PM
