Old 01-26-2008, 11:34 PM   #1
Question Pole Barn
I have a Metal Pole Barn that was wrapped with a type of Insulation that has reflective materal facing the steel and a Bubble Wrap (Plastic?). My problem is, I installed Gas Vent Free Heaters this winter and I have Water at times dripping down the walls. What can I do to stop this from happening?
johns is offline   Reply With Quote
Old 01-27-2008, 12:13 AM   #2
Woodworker and Contractor
Kingfisher's Avatar
Buy a dehumidifyer from Lowes or HD. They run about $100 for a good one run it 24/7 and empty the bucket or run a small drain hose. They have a float switch so they will not over flow.
Kingfisher is offline   Reply With Quote
Old 01-27-2008, 09:59 AM   #3
Question Pole Barn
Thanks for the reply, I have already installed a dehumidfider and it did help a lot. My equipment in the shop seems to be staying dry. However you can see the walls and wood rails are staying wet. I do not have inside walls yet and I am worryed that installing more insulation and then adding drywall I might keep the mositure inside the wall. Any thoughts??
thanks
Old 01-27-2008, 03:56 PM   #4
I know this is more of a question than an answer, but thought it might help.
It's cold outside so when you heat the inside so the metal is sweating like a cold glass of water does. I'm wondering if you took that cold glass of water and wrapped it with some r-13 would it still sweat? So on that note I wonder if you beef up the insulation on your barn and tape the joints so the warm air can't get to the metal would that help?
I rented a warehouse one time and used it to paint a couple of cars. It was a metal building sitting on a concrete slab and had fiberglass insulation with white plastic on the inside. There were two panels in the ceiling that were clear plastic, I guess to let light in during the day. I heated the area with a forced air ready heater and the two clear panels are the only thing I remember sweating. It was about ten years ago and I didn't pay much attention to if it was sweating under the insulation or not.
Wish I could be of more help, just wanted to share my thoughts.
Kirk
I love the smell of sawdust in the morning!
www.kjwoodworking.com
kjwoodworking is offline   Reply With Quote
More On This Topic
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. I want to talk to you for a minute about split bats. What I mean by split bats is when you... Read More »
After a hard workout if your horse has built up a sweat, it is important to make sure that you allow them to walk and to cool off. Also on a wintry day it is important to have a puller handy. The puller is going to keep the horse from getting chilled too... Read More »
Whether you are buying an exterior door for a new construction or you want to replace an older door, it is important to remember that the exterior doors of your home are the first impressions that are made upon your guest. Buying an exterior door is... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. R-Value is the ability of insulation. For instance, right here we are tempting to create two... Read More »
After a hard workout if your horse had built up a sweat, it is important to make sure that you would allow him to walk and to cool off. Also on a wintry day, it is important to have a cover handy. The cover is going to keep the horse from getting chilled... Read More »
I've lost power at my barn Jim Owens Electrical 11 10-12-2008 12:58 AM
Pole Barn Girts, etc... DonAK Carpentry 1 08-16-2007 11:06 PM
pole barn building costs? THEBIGPUNN Building & Construction 1 08-04-2007 07:29 AM
Pole barn slab on a budget zubin6220 Building & Construction 3 06-17-2007 08:23 AM
Wiring a Pole Barn rocky Electrical 8 02-02-2006 08:34 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
