#1 |
Busy DIYer
Poking holes in structure
I am about to drill holes in the base plate of a raised foundation house. Holes will be wide enough to accept 1" PVC conduit for data wiring. Four locations will be drilled, two inside and two outside walls.
What do I need to watch for in order NOT to compromise the integrity of the structure? Sent from my iPhone using DIY Forum |
#2 |
What's a base plate?
Got a picture of where your planning on drilling? Are they going out through the siding, if so what type siding do you have? |
#3 | |
Busy DIYer
Poking holes in structureQuote:
Drilling from underneath, crawl space. All conduits coming into garage where central panel will be located. Siding is stucco. Sent from my iPhone using DIY Forum |
#4 |
Got ya, there called bottom plates and I've never seen them doubled up, top plates get double.
What your doing will have no effect on anything. I'd suggest sealing these holes and any other places under the house where wiring and plumbing were run with some spray foam when your done. |
| Display Modes | |
| Need help caulking and filling nail holes in my trim | hadees | Painting | 13 | 11-25-2012 11:32 PM |
| Patching vinyl siding to "repair" small holes | tomseeley | Building & Construction | 3 | 06-05-2011 10:12 AM |
| Holes in yard under tree - what is it? | Leah Frances | Pest Control | 13 | 05-11-2011 08:22 PM |
| Holes in flange dont match holes in toilet! | ljenkins | Plumbing | 2 | 02-06-2010 08:17 AM |
| Drilling Multiple Holes in Studs | rjschwar | Building & Construction | 6 | 01-27-2010 02:05 PM |
