Old 02-02-2013, 07:47 AM   #1
Point load
Does a new roof load bearing beam need to be point loaded to the foundation
Mathew352 is offline   Reply With Quote
Old 02-02-2013, 07:53 AM   #2
Point load
With that little bit of info how would anyone know?
Old 02-02-2013, 08:02 AM   #3
Point load
The back of my roof was ripped off and a full shed dormer was installed. We then made full 29 for triple 2 by 8 header supported by 6 columns evenly spaced. The roof pitch is now 1/12 on the dormer. The columns sit on the 2 by 6 floor joist about 1 foot back from the bearing wall. Do all of these columns need to go thru the first floor and the basement to the foundatio? Or are they still bearing although not directly on the bearing wall?
Old 02-02-2013, 08:09 AM   #4
Not so new
12penny's Avatar
Point load
What did the architect/engineer specify in the plans?
12penny is offline   Reply With Quote
Old 02-02-2013, 09:44 AM   #5
Framing Contractor
Point load
This should all be on your plans. Do you have plans and a permit?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 02-02-2013, 10:16 AM   #6
Civil Engineer
Point load
"We then made full 29 for triple 2 by 8 header supported by 6 columns evenly spaced." This sentence does not make any sense to me. If you carefully, fully and clearly describe exactly what you did, using actual dimensions, we might be able to help.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
joecaption (02-02-2013)
Wine rack as load bearing wall? lisa7932 Building & Construction 5 02-27-2012 01:53 AM
window condensation kmpittman Windows and Doors 4 11-29-2011 10:10 AM
sweating double pane windows etch Windows and Doors 6 10-31-2011 10:30 PM
Condensation amyevans Windows and Doors 6 10-21-2011 11:11 PM
Load Bearing (point Load) Wall Removal Advice Stringer9 Building & Construction 5 11-09-2010 11:14 AM
