Pocket Doors ...how To Make Fire Rated - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-21-2008, 10:12 PM   #16
Registered User
Termite's Avatar
$100??? I couldn't build them for that. At that price I'd jump all over it if I were you.
Old 07-21-2008, 10:17 PM   #17
BUILDER / REMODELING CONT
buletbob's Avatar
I Understand. Good luck!, Bob
Old 01-17-2011, 09:02 PM   #18
Originally Posted by clasact
I want to put in a set of pocket doors going from the house to the garage but it has recently dawned on me the that door needs to be fire rated if I am not mistaken so how can I do this or is it not feasible and I need to come up with a new plan???? Any info would be much appreciated
Did you find a solution? I'm looking to do the same.
splicer is offline   Reply With Quote
Old 01-18-2011, 01:56 AM   #19
yes I did ,I put in 1 1\2 inch solid oak doors with self closer.The closeris the same thing as you would find on those kithen drawers that close by them selfs and then I hung a heavy plastic curtain on the garage side that is on a pully so you can pull it back out of the way to get in and out but also just unhok the chain and it will slide across by itself.I had the local fire marshal over for a cook out last summer and showed it to him,he told me it more then meet any code in the state and thought it was a great ideal.So far the olny problem is since the doors are heavy I have to keep the tracks clean and oiled well,one bit of dirt and they get hard to move
clasact is offline   Reply With Quote
Old 03-11-2011, 01:42 PM   #20
let me get this straight, you put plastic in front of a rated opening????
kip435 is offline   Reply With Quote
Old 03-11-2011, 02:09 PM   #21
Rewards Points: 5,336
Commercial buildings in the US use this type of door. You see them in lofts in Manhattan that used to be manufacturing facilities.
Try googling "loft doors".
Ron
Old 03-11-2011, 04:46 PM   #22
Old School
Willie T's Avatar
I must have missed something. Without a friction fitting gasket around ALL four edges of at least one side, how do you seal off the air passages (garage chemical fumes) and still be able to open and close the door without the aid of a fairly powerful motor and chain pulley system. This certainly can't be something you can operate with your fingertips, can it?
Willie T
non pocket sliding doors? jamesdart Remodeling 3 03-07-2009 04:48 PM
Pocket Doors Question flyultralite Building & Construction 2 02-27-2008 10:35 AM
Pocket Doors... slakker Carpentry 3 09-07-2007 10:36 AM
Pocket doors ? burita General DIY Discussions 2 01-08-2006 09:38 PM
Pocket Doors wicklowdesigns@yahoo.com Building & Construction 2 07-06-2005 07:21 AM
