Old 07-20-2008, 09:27 PM   #1
pocket doors ...how to make fire rated
I want to put in a set of pocket doors going from the house to the garage but it has recently dawned on me the that door needs to be fire rated if I am not mistaken so how can I do this or is it not feasible and I need to come up with a new plan???? Any info would be much appreciated
clasact is offline   Reply With Quote
Old 07-21-2008, 01:15 AM   #2
Be green & save green
I belive that the door has to be fire rated and you need a self closing latch.
you can probably find a door that is fire rated and install it instead of the actuall pocket door but the self closing latch would be harder to figure out
mgsproperties is offline   Reply With Quote
Old 07-21-2008, 05:40 AM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
Try this Link . they also have self closer. Its a 30min door. check your code!!! for the right rateing.good luck BOBhttp://www.wnibi.com/Building/Story.aspx/6049
Old 07-21-2008, 06:40 AM   #4
Thanks BOB I really didnt think anybody made this type of door that will work just fine
Old 07-21-2008, 07:20 AM   #5
buletbob's Avatar
anytime!
Old 07-21-2008, 07:25 AM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Nice find Bob. (I can imagine the cost, tho...)
- Build Well -
Old 07-21-2008, 07:37 AM   #7
I was thinking the same thing (cost) since they are in the UK but the doors must be fire rated and for he openning I really dont see any other way of doing this.Now if anyone has a better solution I am all ears.
Old 07-21-2008, 07:37 AM   #8
That company is out the UK, so they may not even be available over here.
jerryh3 is offline   Reply With Quote
Old 07-21-2008, 12:11 PM   #9
bravo bob bravo
great find, u learn something new everyday!
Old 07-21-2008, 05:13 PM   #10
buletbob's Avatar
Contact the vender and ask if there is a dealer here in the U.S..
And then see if you can just order the kit with out the door. The door most likly will be cheaper here in the u.s.
Old 07-21-2008, 09:45 PM   #11
Moderator
Termite's Avatar
There is not a code requirement (in the International codes) for the garage door to be self-closing. That requirement is often a jurisdictional call. The code requires either a fire-rated door or a solid core 1-3/8" wood door.
I require them to be gasketed doors to limit smoke/air transfer in a fire, but that is something that is also jurisdictional.
Old 07-21-2008, 10:01 PM   #12
I knew you would come to the rescue on this question termite.Bob had the solution for my problem but after checking with them they are expansive so you are going to save me alot.I would have checked with the local code people but they are a third party examiner and its hard to get ahold of them.I don't really need to follow any ,we have no code for renovations but I am thinking 7 years down the road when I sell this place that having it up to code could get me more out of it.Thanks all who answered
Old 07-21-2008, 10:09 PM   #13
Moderator
Termite's Avatar
I'm not saying it isn't possible, but 1-3/8" thick solid core might be challenging to come up with in a pocket door. I've never seen it done before, but there's nothing that would particularly exclude it from the realm of possibility!
Old 07-21-2008, 10:35 PM   #14
buletbob's Avatar
CLASACT ! Is there a reason why you need a set of pocket doors ????. I Personally don't think its a good idea. i prefer a steel prehung with steel frame. Its much more securer then a pocket door. It will also help against unwanted trespassers. Something to think about.
The Following User Says Thank You to buletbob For This Useful Post:
Willie T (03-11-2011)
Old 07-21-2008, 11:02 PM   #15
I have commercial equipment (stove ,refrig,ovens )in my kitchen the openings going into the kitchen had to be over sized to get them in.All the other exterior doors I put in are standard size so through the garage will be the only way to get them out again.As for security I have solid garage doors and an alarm system oh and a pitt bull so I think I am good their
KC I got a place not 15 miles away I can get solid oak doors made as I want for less then 100 $ I just thought for fire rating they had to be steel but you answered that Thanks
non pocket sliding doors? jamesdart Remodeling 3 03-07-2009 05:48 PM
Pocket Doors Question flyultralite Building & Construction 2 02-27-2008 11:35 AM
Pocket Doors... slakker Carpentry 3 09-07-2007 11:36 AM
Pocket doors ? burita General Discussion 2 01-08-2006 10:38 PM
Pocket Doors wicklowdesigns@yahoo.com Building & Construction 2 07-06-2005 08:21 AM
