-   -   pocket doors ...how to make fire rated (http://www.diychatroom.com/f19/pocket-doors-how-make-fire-rated-23993/)
clasact 07-20-2008 08:27 PM
I want to put in a set of pocket doors going from the house to the garage but it has recently dawned on me the that door needs to be fire rated if I am not mistaken so how can I do this or is it not feasible and I need to come up with a new plan???? Any info would be much appreciated
mgsproperties 07-21-2008 12:15 AM
I belive that the door has to be fire rated and you need a self closing latch.
you can probably find a door that is fire rated and install it instead of the actuall pocket door but the self closing latch would be harder to figure out
buletbob 07-21-2008 04:40 AM
Try this Link . they also have self closer. Its a 30min door. check your code!!! for the right rateing.good luck BOBhttp://www.wnibi.com/Building/Story.aspx/6049
clasact 07-21-2008 05:40 AM
Thanks BOB I really didnt think anybody made this type of door that will work just fine
buletbob 07-21-2008 06:20 AM
anytime!
AtlanticWBConst. 07-21-2008 06:25 AM
Nice find Bob. (I can imagine the cost, tho...)
clasact 07-21-2008 06:37 AM
I was thinking the same thing (cost) since they are in the UK but the doors must be fire rated and for he openning I really dont see any other way of doing this.Now if anyone has a better solution I am all ears.
jerryh3 07-21-2008 06:37 AM
That company is out the UK, so they may not even be available over here.
mgsproperties 07-21-2008 11:11 AM
bravo bob bravo
great find, u learn something new everyday!
buletbob 07-21-2008 04:13 PM
Contact the vender and ask if there is a dealer here in the U.S..
And then see if you can just order the kit with out the door. The door most likly will be cheaper here in the u.s.
Termite 07-21-2008 08:45 PM
There is not a code requirement (in the International codes) for the garage door to be self-closing. That requirement is often a jurisdictional call. The code requires either a fire-rated door or a solid core 1-3/8" wood door.
I require them to be gasketed doors to limit smoke/air transfer in a fire, but that is something that is also jurisdictional.
clasact 07-21-2008 09:01 PM
I knew you would come to the rescue on this question termite.Bob had the solution for my problem but after checking with them they are expansive so you are going to save me alot.I would have checked with the local code people but they are a third party examiner and its hard to get ahold of them.I don't really need to follow any ,we have no code for renovations but I am thinking 7 years down the road when I sell this place that having it up to code could get me more out of it.Thanks all who answered
Termite 07-21-2008 09:09 PM
I'm not saying it isn't possible, but 1-3/8" thick solid core might be challenging to come up with in a pocket door. I've never seen it done before, but there's nothing that would particularly exclude it from the realm of possibility!
buletbob 07-21-2008 09:35 PM
CLASACT ! Is there a reason why you need a set of pocket doors ????. I Personally don't think its a good idea. i prefer a steel prehung with steel frame. Its much more securer then a pocket door. It will also help against unwanted trespassers. Something to think about.
clasact 07-21-2008 10:02 PM
I have commercial equipment (stove ,refrig,ovens )in my kitchen the openings going into the kitchen had to be over sized to get them in.All the other exterior doors I put in are standard size so through the garage will be the only way to get them out again.As for security I have solid garage doors and an alarm system oh and a pitt bull so I think I am good their
KC I got a place not 15 miles away I can get solid oak doors made as I want for less then 100 $ I just thought for fire rating they had to be steel but you answered that Thanks
