Pocket Door And Wall Install - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-10-2013, 02:22 PM   #1
Rewards Points: 101
pocket door and wall install
My wife and I live in a 1983 Wycks doublewide on a permanent block foundation. I am about to remove the wall between the main bedroom and dining room (1X4" studs) and install a new wall with a 36" pocket door, which brings me to my question: If I install this door with a Johnson 100721DR pocket door kit, do I need to use 2 X 4 or 2 X 6" lumber to achieve the clearance? There is also a light switch where the door would slide into the new wall, and I feel that if I used 2 X 6" studs I would have enough clearance for the switch (in a UL approved switch box, of course!) Any answers? Thanks!!
eric woodall is offline   Reply With Quote
Old 01-10-2013, 03:29 PM   #2
Haverhill Trade 1965
Most pocket door frames are made for a 2 x 4 wall. You would have to build out the pocket frame 2", or 1" each side to be centered for a 2 x 6 wall.
Duckweather is offline   Reply With Quote
The Following User Says Thank You to Duckweather For This Useful Post:
eric woodall (01-10-2013)
Old 01-10-2013, 04:25 PM   #3
Rewards Points: 2,210
Here we can get thinner boxes where they are needed. Remember any ground screws or such that stick out the back of the box.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
