Pocket Door Help - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-08-2010, 03:41 PM   #1
Question
pocket door help
I recently installed a pocket door where an existing door was. This is an old house with interior plaster walls, the wall framing is off in several walls.
I followed the johnson instructions- connected the header in between the existing 2x4, made sure everything was level and hanged the door. For some reason the door is not in the center of the encasing and the door is hitting the casing. Also the door does not end up at the center of the opposite end, where I am placing the door lock. As of now I have one wall still open and pulled on the vertical metal studs and the door is not hitting, but now there is an unevern gap where the door ends and where the trimming needs to be place, one side of the trim is one size and the other side is another.
Most intructions on pocket doors is for adjusting the rollers so the door is even vertiically with the jam, I have not found info when the door don't hang straight from the header to the floor.
I have installed several pocket doors and never encounter this problem. Any help would ve appreciated.
I am also changing all the interior doors and they are all off and cutin alll four sides to fit the bad framing, Probably the best way I though is to removed the entire casing and put pre hang doors- except that the wall with the plaster comes to around 5 1/2 inches and standard pre hung door jam is 41/2. Purchading the 5 1/2 jams cost a fortune, any tips?
samuel11 is offline   Reply With Quote
Old 08-08-2010, 04:01 PM   #2
fabrk8r
fabrk8r's Avatar
Is the wall you are installing the pocket door into perfectly plumb?
Is the door off center through it's entire height or just at the bottom, or top?
A picture would help.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-08-2010, 04:27 PM   #3
I don't think the wall is plump- I will get some pictures; I am trying to help my daughter and her husband fix this old house. I'll get more details soon. Thanks.
Old 08-08-2010, 04:33 PM   #4
fabrk8r
fabrk8r's Avatar
Put a 4 foot level on the wall and make sure it is vertical (plumb).
If it is not plumb (within reason) you will have problems with a pocket door rubbing on the framing.
Old 08-08-2010, 10:25 PM   #5
pocket door
Thank you, I will be heading o my daughters tomorrow and check the wall with the level, hopefully it is.
Old 08-19-2010, 02:24 PM   #6
pocket doors
I WAS FINALLY ABLE TO GO TO MY DAUGHTERS. tHE WALL WAS NOT PLUMP AND AND ALSO THE RECEIVING WALL IS I/2 OFF. I don't know what to do, the walls are platered so they made up the misaligments on the walls.
I'll try to pots the photos.
However, we noew have another problem, in order to put the sliding door, we cut the toilet vent thinkt we could put another one in the outside wall- once we open the floor we discovered it is more than what we know. We called several plumbers and they want a fortune and it seems they are not sure what to do either. I will post the pictures and skecht in the plumbing forum and see if anyone has ideas.
Thanks.
pocket door help-dscf0371.jpg   pocket door help-dscf0372.jpg   pocket door help-dscf0373.jpg   pocket door help-dscf0375.jpg   pocket door help-dscf0377.jpg
Old 08-19-2010, 03:07 PM   #7
Rewards Points: 3,130
I am almost finished building my own log home. Every interior door is a pocket door. Trust me, if your walls are not plumb within 1/4" or so, a pocket door will never work.
Old 08-19-2010, 03:44 PM   #8
pocket door
I hear you, I may need to go back to the regular door. I am trying to see if I can get a vent from the side to the outdoor wall of the wall on the right, otherwise, the pocket door is off.
Is a pocket jig the way to go? roxksears Carpentry 25 11-30-2009 06:27 PM
pocket hole joinery for cabinet doors? Jeremy Hillary Boob, PhD Carpentry 4 03-09-2009 06:26 PM
pocket door help cmnelson74 Remodeling 1 03-06-2009 03:19 PM
Considering Pocket Entry Door at top of stairs snsdiy Remodeling 6 01-06-2009 07:39 AM
pocket door coming off track jimmy21 Building & Construction 6 10-06-2008 03:28 PM
