Old 12-07-2006, 12:56 PM   #1
Pocket door
Hi all,
I am installing a pocket door 28" with an overall span of 56". The wall this is going in is a load bearing wall. There is a top plate of solid wood 4x4. Could that suffice the load of the opening or do I need to put a header in also above the opening. Thanks
TonyD
TonyD is offline   Reply With Quote
Old 12-07-2006, 06:04 PM   #2
Pocket door
Is there currently a door there now?
What is above the load bearing wall? A hot tub or other heavy item?
redline is offline   Reply With Quote
Old 12-08-2006, 08:08 AM   #3
Pocket door
The Door Size Currently There Is 30 Inch Opening. No Hot Tub Or Heavy Items Above In That Area.
Tonyd
Old 12-08-2006, 06:08 PM   #4
Pocket door
a 4x8 or sandwiched 2x8s are legal to span 60 inches in most areas.
jbob is offline   Reply With Quote
Old 12-08-2006, 07:46 PM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Pocket door
Originally Posted by TonyD View Post
Hi all,
TonyD
You will absolutely need to put a header in.
- Build Well -
Old 12-13-2006, 08:03 AM   #6
Pocket door
Im Going To Put In A Double 2 X10 Header...that Should Be Ok....
Tonyd
French Doors from Homedepot or Lowes??? johnnytuinals General Discussion 47 01-10-2009 11:00 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 09:43 AM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
Walkout Basement Door allworld Building & Construction 1 06-17-2006 01:50 AM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 03:09 PM
