-   -   Pocket door (http://www.diychatroom.com/f19/pocket-door-5270/)
TonyD 12-07-2006 11:56 AM
Pocket door
Hi all,
I am installing a pocket door 28" with an overall span of 56". The wall this is going in is a load bearing wall. There is a top plate of solid wood 4x4. Could that suffice the load of the opening or do I need to put a header in also above the opening. Thanks
TonyD
redline 12-07-2006 05:04 PM
Is there currently a door there now?
What is above the load bearing wall? A hot tub or other heavy item?
TonyD 12-08-2006 07:08 AM
The Door Size Currently There Is 30 Inch Opening. No Hot Tub Or Heavy Items Above In That Area.
Tonyd
jbob 12-08-2006 05:08 PM
a 4x8 or sandwiched 2x8s are legal to span 60 inches in most areas.
AtlanticWBConst. 12-08-2006 06:46 PM
Originally Posted by TonyD (Post 26211)
Hi all,
TonyD
You will absolutely need to put a header in.
TonyD 12-13-2006 07:03 AM
Im Going To Put In A Double 2 X10 Header...that Should Be Ok....
Tonyd
