Plywood Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-30-2009, 01:48 PM   #1
Rewards Points: 320
plywood walls
Hello,
I have a house that was built in 1839 in Charleston SC (hurrican risk). Several years ago, the plaster was removed from a majority of the walls in the house and replaced with 1/2" plywood. There is no sheething on the exterior just wood siding. Some builders have told me to leave the plywood up and just drywall over it, as the plywood is what is giving it sheer strength which the drywall couldn't provide. Can anyone give any more insight as to whether it's worth it to leave the plywood in, or if having the wood siding on the exterior and drywall on the interior would be sufficient?
Thanks!
autx790 is offline   Reply With Quote
Old 09-06-2009, 01:50 PM   #2
We just bought a 1940's dutch colonial house and realized the house has plywood walls and we are trying to see if we can paint them or need to tear them down and put up dry wall. Any thoughts??
4dogs is offline   Reply With Quote
Old 09-06-2009, 02:19 PM   #3
Civil Engineer
Rewards Points: 4,514
SC: The builders who advised you that the plywood provides greater shear strength than plaster were correct. Plywood is very strong in shear, and will greatly improve hurricane survivability when it is correctly installed to a wood framed wall. Proper attachment means an adequate number of nails or screws per square foot of plywood.
I am not familiar with proper technique for sheet rocking over plywood, no doubt someone on this site can help you out there, but I would definitely not touch that plywood.
Old 09-06-2009, 03:53 PM   #4
Registered User
Termite's Avatar
You can rock directly over the plywood. Not a problem.
The siding and rock alone is definitely not enough to survive a wind event, let alone a hurricane. Here in KS we design for a 3 second 90mph gust, and having no exterior sheathing would be a BIG problem. Sheathing the interior with plywood isn't ideal because it doesn't lap the rim joist(s) but is better than nothing for sure. Leave that plywood there!
Old 09-06-2009, 04:02 PM   #5
Post
plywood
Hi, I do agree to keep the plywood and I see absolute no reason why it can not be covered whith drywall sheets, as long the walls are able to breath. Meaning is: that normal humidity can evaporate freely (no plastic in between) and good vetilation is provided, because you have high humidity down there. Just keep in mind moistre accumulates always on the warm side. Just look at your ice cold soda/beer. LOL On the outside just use a moister barrier, wich will let escape moister, but will block it from comming in. Since SC is a high humit region I would build an air space between wall and plaster for circulation good luck
jochenww is offline   Reply With Quote
Old 09-08-2009, 04:33 PM   #6
Drywall contractor
Rewards Points: 1,068
Glue and nail/screw drywall directly to the plywood. You could use 1/4" or 1/2". With 1/4" you could probably get away with butting to your window and door trim and flat taping. There would just be less "reveal". I would pull the base and replace after drywall unless it's a 1"x with base cap. (You could pull the base cap, hang to the 1"x and add new cap.) With 1/2", you'll pretty much have to pull all the trim, add jamb extensions to the windows and doors, drywall, then all new casing and base......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 09-10-2009, 10:19 PM   #7
Rewards Points: 320
Thanks for the feedback, very helpful! It looks to be about 1/4" plywood, if that's still plywood. I think this house still had the plaster up when Hugo went through and there was no structural damage to this house, or any others around here, which was good to hear. I guess I'll go ahead and leave it and put some good drywall over it.
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 09:17 AM
Tiling - Gap in plywood (sub)floor mcg Remodeling 5 01-15-2009 05:21 PM
Replace exterior walls or build false walls Medic507 Carpentry 3 11-12-2008 10:48 AM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 03:50 PM
