Plywood Underlayment Installation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-07-2009, 08:54 PM   #1
Rewards Points: 37
plywood underlayment installation
I'm currently rippout our some old engineered hardwood and the 5/8 particle board it's glued too. Our subfloor is 1/2 OSB. I'm installing 23/32 plywood overtop as my underlayment for my new 5/16 Brazillian Walnut floors. I'm leaving roughly 1/8" gaps between panels and 1/4" at all vertical surfaces. Sometimes the gaps between panels are up to a 1/4 inch as well depending on how straight I have the panels cut.
Should I fill the gaps between panels with silicon or anything like that and sand the edges?
interplexr is offline   Reply With Quote
Old 02-08-2009, 08:45 AM   #2
Remodeling Contractor
If you are talking about the plywood panels the answer is no. Caulking would simply pop out when the expansion of the panels occur. They are fine the way they are.
Tags
gaps , hardwood , plywood , subfloor , underlayment
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 07:06 PM
Sheet Vinyl....plywood underlayment or luan? AllGoNoShow Flooring 3 05-28-2008 05:57 PM
Hardwood floor installation on 2nd floor - underlayment necessary? digexpressions Flooring 2 11-30-2007 10:15 AM
laminate floor underlayment installation? KUIPORNG Flooring 1 03-08-2007 05:52 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 07:44 PM
