Plywood Soffit - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-11-2010, 07:00 PM   #1
plywood soffit
Can I purchase the plywood soffit with the air vents already cut in them.
Cliff Plank is offline   Reply With Quote
Old 09-11-2010, 09:48 PM   #2
remodeling pro
I have never seen such a product.
troubleseeker is offline   Reply With Quote
Old 09-12-2010, 11:18 AM   #3
Registered User
Rewards Points: 5,466
NO, I doubt if they would be the exact correct width. If you make your own, use continuous vent near the fascia board for optimal performance, pp. 616: http://books.google.com/books?id=Z8a...0vents&f=false
In white or brown: http://www.lowes.com/SearchCatalogDi...+vents&x=0&y=0
Gary
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-13-2010 11:09 PM
Basement Fireblocking within HVAC Soffit ssmith147 Building & Construction 3 12-31-2009 06:36 AM
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 09:15 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 07:47 PM
Another Ridge Vent, Gable vent and soffit question (??) davco Roofing/Siding 2 04-30-2007 11:14 PM
