Plywood Siding T1-11 - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-02-2009, 10:14 PM   #1
Rewards Points: 260
Plywood siding T1-11
The bottom of this siding always seems to get damaged (T1-11). I noticed some people repair the siding instead of replacing the entire sheet. They will usually just cut the damaged section out and splice in a new sheet with z flashing. What does this do to the building structurally? The T1-11 in my area is applied directly to the wall studs. It acts as the sheathing and siding.
bluefitness is offline   Reply With Quote
Old 04-03-2009, 12:25 AM   #2
Registered User
Rewards Points: 5,204
That is acceptable, but it is not the prettiest thing, unless it's a place less noticeable. Set the saw to just 5/8" deep and if you do cut the paper underneath, put new paper in the slot and overlapping paper below for moisture rundown. Structurally, as long as one full sheet remains on each corner, and one every 25' away, you're fine. If 5/8", be sure to use 5/8" z-metal and caulk the ends. Be safe, GBAR
Old 06-03-2009, 04:30 PM   #3
Rewards Points: 260
thank you
I talked to a contractor and he suggested cutting it under the frieze board right under the soffits. I was planning on doing this to one piece that has some damage. The sheet is at the corner of a gable structure. There will still be a solid piece on the gable end. Do you see any problems with this? I can replace the whole piece if need be.
Old 06-03-2009, 05:09 PM   #4
Registered User
If the sheet is on the corner of the ground floor, replace the whole thing. Here is why, under wall bracing-- #3--.
And also read plywood diaphragms, scroll towards the bottom.
About all edges blocked: http://www.mcvicker.com/resguide/page009.htm Be safe, G
Ship lapped plywood siding bluefitness Building & Construction 6 02-05-2009 10:35 PM
Rotten plywood under siding thisolddump Building & Construction 8 05-12-2006 10:43 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
