Old 05-28-2012, 08:46 AM   #1
Plywood sheathing gap
Hello and I apologize for such basic question. How much gap is normal between sheets of plywood sheathing for exterior walls? I've heard 1/8" Our framers have done great work so far but in one area where the window size was reduced, I can see about 1/2" gap but covered by Tyvek. I think I am just being paranoid but should I ask them to re-do this or just put silicone over the gap? I just don't want to use anything that might cause the plywood to not expand and eventually bow...
Many thanks!
sbkim is offline   Reply With Quote
Old 05-28-2012, 11:43 AM   #2
Post a picture.
If this gap around a window opening or in the field?
If this is a butt joint 1/2" is way to much.
Old 05-28-2012, 02:09 PM   #3
Originally Posted by joecaption View Post
Post a picture.
Absolutely - should have done from the beginning.
Old 05-28-2012, 02:20 PM   #4
Moderator
kwikfishron's Avatar
Just point it out to your framer. He'll likely just add a block below the top plates, which is fine.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 05-28-2012, 03:25 PM   #5
Thanks sounds like an easy fix...
Painting exterior plywood wall sheathing hiphi45 Building & Construction 2 12-24-2011 01:12 PM
Plywood sheathing vs subfloor vs underlayment acerunner Carpentry 6 06-24-2011 10:31 PM
plywood/ osb scraps for sheathing? nicole21 Roofing 4 09-08-2010 11:41 AM
horizontal or vertical plywood sheathing. Clutchcargo Building & Construction 6 07-12-2009 02:51 PM
Do I need plywood over t&g sheathing on this house?? 4just1don Building & Construction 5 11-17-2008 12:20 PM
