Plywood Sheathing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-24-2013, 02:35 PM   #1
Rewards Points: 27
Plywood sheathing
I just replaced all the plywood on my house and gaped it at 1/8 horizontal and 1/4 vertical. My question now is can I fill these gaps and around the top and bottom with silicone? I'm going to be installing tyvek in the next few days do I silicone the top and bottom of it also?
kujo is offline   Reply With Quote
Old 04-24-2013, 04:38 PM   #2
kwikfishron's Avatar
Rewards Points: 602
No... there is "NO" reason to do that.
kwikfishron is online now   Reply With Quote
Old 04-24-2013, 05:03 PM   #3
Rewards Points: 3,130
Waste of time and money. Why did you do 1/4" vertical gaps?? Never heard of that.
Old 04-24-2013, 05:32 PM   #4
Rewards Points: 602
Old 04-24-2013, 06:47 PM   #5
Rewards Points: 27
I wrote that backwards I did 1/8 vertical and 1/4 horizontal because I was told to since the previous plywood buckled all over the house and roof.
Old 04-24-2013, 09:25 PM   #6
Rewards Points: 626
If you want to seal the seams buy a few dozen rolls of bitumin flashing tape. It Self sticking tack it up with arrow stapes. Tyvex over it your fine.
Nailbags is offline   Reply With Quote
Old 04-24-2013, 10:04 PM   #7
Registered User
Rewards Points: 5,516
The gaps are required for plywood/OSB (expansion- don't fill them), which type sheathing buckled before? Which type are you now using and describe the wall make-up, please.
Gary
lay vinyl tile on patched holes in plywood charotte Flooring 5 10-25-2012 07:59 AM
How to attach plywood to subfloor Billdd Flooring 6 08-05-2012 04:27 PM
OSB or plywood? crewguy Building & Construction 13 11-20-2010 11:43 AM
plywood damaged by water hendjl Building & Construction 4 11-03-2009 06:47 AM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 12:11 PM
