Plywood Question For Outdoor Application - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-04-2013, 08:01 PM   #1
Plywood question for outdoor application
Hello!
I'm going to attempt to install a tongue and groove flooring on the ceiling of my covered structure over my patio. Can someone tell me which type of plywood would work best for this? The wood would not be exposed to rain or sun, but I do live in NE Ohio and we get a vaired range of temperatures and humidity. Anyone have any reccomendations? Thanks!
slrohlik is offline   Reply With Quote
Old 04-04-2013, 08:48 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,212
if your not looking for a smooth finish either use fir plywood or sheathing grade
woodworkbykirk is online now   Reply With Quote
Old 04-05-2013, 07:00 AM   #3
AHH, SPANS!!!
Rewards Points: 1,166
I'm not sure I understand the question. are you wanting to put sheathing up to the ceiling and then go over that with T&G? if so then standard OSB should be good behind the T&G.
hand drive is offline   Reply With Quote
Old 04-05-2013, 08:30 AM   #4
Roofmaster
Rewards Points: 2,210
All plywood today is made with exterior glue. I would use 23/32 (5) ply minimum fir plywood for good nail retention. OSB is a pain to nail into. I would install the T&G with my pneumatic stapler with 1/4 inch x 1.5 inch resin coated staples, about 1 ft. on center. As far as grade goes, you can use CD Exposure 1 with the C side down. BC would be better with the B side down.
Old 04-05-2013, 07:55 PM   #5
firehawkmph's Avatar
Rewards Points: 1,884
Why not use tongue and groove 1 x 6 pine and forget the plywood. Nail it right to the ceiling joists with a 15 ga. finish nailer and 2" nails.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 04-06-2013, 07:22 AM   #6
AHH, SPANS!!!
^ that brings back memories of the mountain job and running that 1x6 T&G on the ceilings all day. that is a loud echoing job!get the wood bender!!
Tags
outdoor flooring , plywood
lay vinyl tile on patched holes in plywood charotte Flooring 5 10-25-2012 07:59 AM
How to attach plywood to subfloor Billdd Flooring 6 08-05-2012 04:27 PM
question about exterior vapor barrier integrity.... diy'er on LI Building & Construction 15 04-10-2012 05:50 PM
Nailing Rigid Foam Boards to Plywood Buscador Roofing/Siding 5 02-05-2012 06:22 PM
