Old 08-11-2010, 03:07 PM   #1
plywood on fire rated wall
I have living space over a garage. By code, the ceiling needs to be fire rated, which is usually done with 5/8" type X drywall.
My ceiling, however, is covered with plywood. I can't tell how thick as it was installed by previous owner. Is plywood ever acceptable as a fire rating? I think I might have to replace it.
acerunner is offline   Reply With Quote
Old 08-11-2010, 03:40 PM   #2
Thrasher
There is fire rated plywood that you can replace it with.
Lulimet is offline   Reply With Quote
Old 08-11-2010, 04:23 PM   #3
jlhaslip's Avatar
or leave the plywood and cover it with taped 5/8" type x
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 08-12-2010, 01:37 AM   #4
how can I tell if plywood is fire rated? It is painted over, so I won't be able to see any markings. Also the garage door supports & opener is mounted on it, so it'll be hard to work around it.
Old 08-12-2010, 09:17 AM   #5
I'd stay away from fire-rated plywood. It either isn't very fireproof (the WOOD part of plywood) or it will have tons of chemicals in it that aren't needed to accomplish what you seek.
I'd cover it with the thickest d/w you can find 5/8" or so and be done with it. Plywood makes an excellent base to attach drywall.
Hohn is offline   Reply With Quote
Old 09-06-2010, 01:24 AM   #6
However you need to keep this in mind. Plywood delaminates which leads to fire spread. what is above the current plywood? are you attaching directly to the joists?
if you are you now have a void space. any fire in this void space with be able to spread very fast if it is lined with plywood. This fire will also go unnoticed for a while. Depending on what type on construction (balloon frame, platform, lightweight...) a small fire else where will easily travel to these voids and just take off.
do you have floor truss? do you have 2x6? Do you have wooden i beams?
if you have a wooden truss floor or a wooden I beam you might get 5 minutes of fire on these members before they fail.
Also there is no fire rated drywall. I'll say this again THERE IS NO FIRE RATED DRYWALL....one more time.....THERE IS NO FIRE RATED DRYWALL did you get that? THERE IS NO FIRE RATED DRYWALL!!!!!!!!!!
what you have a fire rated ceiling assemblies. These are tested as a whole unit down to the type of nails and tape and if insulation is needed. make one change and you DO NOT have a fire rated ceiling. you can not take one part of the assembly and say it it is fire rated.....no mater what the a contractor tells you. Drywall can be fire-resistant......this is not the same as fire rated. Sheet metal is fire resistant.....would you use that that a firewall? I hope not.
Don't belive me...... from one of the largest makers of Type X drywall
What is the fire rating of one layer of the fire-rated gypsum panels? A: There is no rating on a board by itself. Fire ratings are allocated only to systems.
a 1/16" gap between the drywall and it is the same as if you didn't have it. Fire will find this path. Light fixture punched in the drywall....yup fire will by pass your so called fire wall. This is why you have to follow the ceiling assembly guidelines and not just toss anything up there. Those metal screws that you decided not to cover correctly.....
Don't believe me? Do it anyway you want.....good chance no one will inspect it very well. This is what keep me busy....nothing like a good garage fire that is attached to a house.
want a good read......buy a fire service building construction book or just about any fire strategy book. They are normally filled with examples like this and the outcomes are never good.
PM me and I'll recommend a few....they will open your eyes....
firedogut is offline   Reply With Quote
The Following User Says Thank You to firedogut For This Useful Post:
nap (09-06-2010)
Old 09-06-2010, 01:10 PM   #7
I'm sorry that the post came across angry and in poor tone
I had a long day and DIY and contractors who spread false info in regards to fire safety just really get under my skin. Again sorry for the tone.
Please keep in mind that buildings codes do way below what should be done in terms of fire safety. Cutting corners makes it even less.
A few simple things I recommend every home owner does that not in any building codes
Hvac system in attic or void space? Put a smoke detector in the attic above the system. Most local fire departments will give you a free one. If your hvac/ heater has a small fire you will know before your attics is nothing but flames. Most smoke detector in the living space won't go off until an attic fire is big.
Same with closets with hvac systems and water heaters. Laundry chutes and dumbwaiters could use ones close by.
Don't use a torch to defrost metal pipes unless you can keep the pipe cool. Copper will transfer heat into the walls and may catch items on fire. Very common
If you smell smoke or think there is a fire call 911 and get family out. Keep all doors and windows closed. Let the fire department find the cause of the smoke
Off soap box. Again bad day at work, needless deaths and injuries.
Old 09-06-2010, 02:44 PM   #8
Tom Struble's Avatar
Tom Struble is offline   Reply With Quote
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-21-2010 12:26 AM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 06:10 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 04:43 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
