Plywood Exterior Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-26-2011, 10:42 AM   #1
plywood exterior walls
will 7/16 inch thickness of plywood be acceptable as opposed to 1/2 inch? I live in a cold zone where temps can get down to -35 Celsius,,+30 Celsius in the summer,,I am replacing the exterior walls on my mobile home,and should I place them vertically or horizontally,,,
BillPeen is offline   Reply With Quote
Old 08-26-2011, 07:04 PM   #2
Rewards Points: 5,336
They're basically the same material.
It's the insulation you use that will deal with the heat and cold.
Install the plywood horizontally and offset the joints.
Ron
B. Franklin 1759
Old 08-27-2011, 11:43 PM   #3
Registered User
Rewards Points: 526
Check with your local B.D., the walls may need to tie to the frame; http://www.huduser.org/search/Bibliography.asp?id=3168
You may also need solid blocking for shear when running the wall sheathing on its side;http://www.apawood.org/pablog/index....al-or-Vertical
More on mobiles; http://www.tiedown.com/pdf/dstructural.pdf
http://publicecodes.citation.com/ico...002_par052.htm
Gary
Roofing plywood advice needed jimd206 Roofing/Siding 2 04-24-2011 11:58 PM
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 02:52 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 05:08 PM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-13-2010 11:09 PM
plywood damaged by water hendjl Building & Construction 4 11-03-2009 06:47 AM
