Old 11-02-2009, 04:08 PM   #1
Default plywood damaged by water
I have a 6" step into my shower. It was made with framing lumber, then a foil backed plywood covering the lumber, then concrete board over the 1/2" plywood, Then tiled and a shower door installed. The two walls of the step are splitting apart from the top of the step allowing water to enter through the cracks in the grout. I suspect the plywood got wet and expanded. The tile is not cracked, only the grout.
Is there a product to inject into the plywood through the cracks in the grout that would keep the plywood from expanding further thus preserving the tile work?
If there is not, then I suspect i will have to take off the shower door, tear out the tile on the step, take off the damaged plywood. What is the product to replace it with to assure this does not happen again?
hendjl is offline   Reply With Quote
Old 11-02-2009, 09:23 PM   #2
There is no magic substance that will counteract water intrusion. You will need to open the area up and replace the damaged wood. There will be more damage than is evident. Don't be surprised if you need to replace the entire base.
As an alternative to a wood curb, look into Schulter and the curb they sell. The difficult part is integrating and waterproofing one aspect of a system.
Ron
Old 11-02-2009, 09:38 PM   #3
If the Schleuder system isn't what you are looking for there is a product called Red Guard that you paint onto your surface before tiling. The Red Guard dries into a ruberized membrane. It works pretty good when you are having to do repairs and want to make sure that you have the subsurface sealed tight.
RobQuillin is offline   Reply With Quote
Old 11-03-2009, 12:39 AM   #4
Thank you both.
Old 11-03-2009, 08:47 AM   #5
ccarlisle's Avatar
I'd say you have one of countless millions of showers made in the past 50 years (and that are still being made that way) that experience the same problem. In essence they are made to fail within a short time; it is only recently that people have come to understand that there are solutions to it that don't cost the earth to implement.
It is said that the average shower walls and floors receive more water on them per unit area than than your roof does - and I believe it. Ultimately, you will have to waterproof the whole shower stall in order to put future mould problems to rest.
ccarlisle is online now   Reply With Quote
More On This Topic
Okay, now let's begin grouting our project. You just take, on the pallet knife a big glob of the grout and just press it right on like you're frosting a cake. Now you want to get into all the crevices and on the sides like this. All the way around. Bring... Read More »
In this section I'm going to show you a little bit about using grout. You can buy this at any lumber store or hardware store. Get a spoon like this to mix it up with. I'm just going use a little bit, because I'm just going to demonstrate it on there, and... Read More »
I’m Lee, I have a degree in architecture and about ten years experience in the construction field. Today we have been installing a designer counter top and we’re ready to grout it. You just want to buy the grout color of your choice- we’... Read More »
At times, everyone who has tile countertops will need to re-grout them to freshen their appearance. Rather than paying an expert, this is a job the average do-it-yourself home-improver can handle. By following a few grouting tips, you'll have a beautiful... Read More »
Today we’re going to be re-grouting the tile around the window in the bathtub. Once your grout has set out for about five to eight minutes, you get yourself a grout trowel, which is just spongy so you can apply the grout. And you just scoop some... Read More »
Low hot water pressure crebive Plumbing 24 11-07-2009 09:55 PM
How to Replace water damaged outside wall cmnuzzo Building & Construction 1 09-18-2009 01:58 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 01:41 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 10:09 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 12:31 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
