Plywood Ceiling Vs Drywall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-18-2011, 03:18 PM   #1
Plywood Ceiling vs Drywall
Hello,
My garage and laundry area of my home have unfinished vaulted ceiling (i.e., I can see nails from roofing, wires, pipe). I would like to panel it, my contractor told me to use Dry Wall and screw it into stud. But, it seems to be too heavy for me to do it alone. So, I am thinking of using 1/4" plywood (I noticed MDF middle layer with birch (wood) finish). can anyone tell me pros and cons of this?
- Fire Code? - like 5/8" drywall is required)
- Mold? - because now, my ceiling is enclosed
What if I use solid pine wood instead (8'x1')? or thicker plywood?
thone is offline   Reply With Quote
Old 04-18-2011, 03:39 PM   #2
kwikfishron's Avatar
Rewards Points: 1,016
Rent a sheetrock jack. It will be like lifting that 5/8” rock with one finger.
kwikfishron is online now   Reply With Quote
Old 04-18-2011, 03:41 PM   #3
Rewards Points: 5,336
You need the fire code sheetrock and a drywall lift. You can rent one for under $50.00 a day. Mine can lift to 11'6" without an adapter(15').
Ron
Old 04-18-2011, 06:43 PM   #4
Thanks a lot.
Now I know!!
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
framing ceiling for drywall artlover13060 Drywall & Plaster 1 07-04-2010 10:25 AM
finishing a drywall ceiling mmhendrie Building & Construction 12 03-17-2009 09:11 AM
wet attic insulation and ceiling drywall rojas66 Drywall & Plaster 4 03-04-2009 03:33 PM
Plaster Ceiling and drywall dprasan Remodeling 6 02-05-2008 11:34 PM
