Plywood Ceiling - Screw Sizes - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-22-2009, 04:18 PM   #1
Rewards Points: 91
plywood ceiling - screw sizes
I'm about to screw plywood into the 2x6 ceiling joists - It's 3/4 inch plywood, and I have either 1 1/4 inch coarse thread drywall screws, or 2 inch fine thread drywall screws - which should I use, or is neither suitable?
mmhendrie is offline   Reply With Quote
Old 03-22-2009, 05:07 PM   #2
Rewards Points: 91
I also have 2 1/2 inch exterior screws if those are better - any advice?
Old 03-22-2009, 06:22 PM   #3
Crazy, but lovable
flyboy2610's Avatar
I would use the 2-1/2 inch screws.
Why are you putting up a plywood ceiling?
flyboy2610 is offline   Reply With Quote
Old 03-22-2009, 07:20 PM   #4
Rewards Points: 91
plywood, then cover in drywall and screw in every 8inches, then redguard and tile - the ceiling over a schluter shower - plywood gives extra support with 20 inch joists
Old 03-22-2009, 07:42 PM   #5
I agree 2 1/2 inch screws. Can I get a picture of the finish product?
Toolmaster is offline   Reply With Quote
Old 03-22-2009, 07:48 PM   #6
Rewards Points: 91
the finished shower, or the hung drywall?
Old 03-22-2009, 07:53 PM   #7
Remodeling Contractor
Not sure where these ideas are coming from. But coarse thread.. the length most be the depth of the material plus 1" and not more into the studs. The screws or nails will more if they are driven deeper than 1". So 2" would be better than 2 1/2"
Old 03-22-2009, 07:54 PM   #8
the finished shower.
Ceiling fan - Downrod won't screw in all the way tima2381 Electrical 8 05-02-2012 03:57 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Expand/Contract: Glue & screw 7" x 3/4" OSB strips on top of 3/4 plywood subfloor ? iMisspell General DIY Discussions 8 05-11-2009 08:09 PM
plywood ceiling over shower mmhendrie Building & Construction 4 03-20-2009 01:26 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
