Plumbing In Load-bearing Wall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-27-2009, 02:01 PM   #1
Rewards Points: 3,130
Plumbing in Load-bearing Wall?
Is is legal to run plumbing in an interior load bearing wall?
Old 02-27-2009, 02:48 PM   #2
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
usually, a plumber cuts anything and everythin in their way. most of them either don't know the difference or don't care what a load bearing wall means. a little more information is needed so we can answer this. Answer these questions for us...
What size is the pipe?
Is the plumbing running horizontally or vertically?
How many (size of lumber here) needs to be cut or drilled?
Where is the hole or notch located? Middle, top, or bottom.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 02-27-2009, 05:12 PM   #3
Registered User
Termite's Avatar
General answer, yes, its legal.
General I-codes overview:
You can drill holes up to 40% of the depth of a stud in a load bearing wall, provided the holes are centered. Holes between 40% and 60% can be drilled provided the stud is doubled and no more than two successive studs are doubled. A hole can never be located within 5/8" of the edge of a stud, no matter what the hole size is.
The top and bottom plates can be drilled or notched to 50% of their depth without need for structural modification.
Old 03-02-2009, 07:56 AM   #4
Thanks for the reply. My question was a general one as I am working on the plumbing layout for a log house I'm building. It has only one interior load-bearing wall. My layout will be a lot easier if I can run the main stack through it. That would likely be the only pipe other than maybe a vent.
Old 03-02-2009, 08:06 AM   #5
are you making that wall out of 2"X6"'s? It will make your life a lot easier.
II Weeks is offline   Reply With Quote
Old 03-02-2009, 12:53 PM   #6
Yes, that's the plan. But even so, I'm not sure I could put the main stack in the wall.
Old 03-02-2009, 12:58 PM   #7
kemerick's Avatar
Rewards Points: 87
Comedy, but true. Inside the load bearing walls of my remodel, the plumbers annihilated the wall structure and it still passed inspection.
My constant project is my home, my play time is usually spent on my CNC router.
kemerick is offline   Reply With Quote
Old 03-03-2009, 07:49 AM   #8
I plan to do the plumbing, so that isn't likely to happen.
load bearing wall and chimney learntobuild Building & Construction 2 01-13-2009 12:30 AM
Bearing wall, HELP me please jamiedolan Building & Construction 7 11-03-2008 12:33 PM
load bearing wall no more grant Building & Construction 5 10-14-2007 09:50 PM
Load Bearing Wall or not?? dtmbizzle Building & Construction 3 07-16-2007 08:12 AM
