PLEASE HELP!! Sticky Tar Residue On Chimney Walls! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-11-2010, 10:40 AM   #1
Question
PLEASE HELP!! Sticky tar residue on chimney walls!
I hope someone can help me! Moved into an old 1830s house with oil fired heating. Worked fine but now notice in the roof space and bedroom below there is a sticky tar residue on the walls. The boiler is in the washroom downstairs and these marks are where the chimney walls house the liner for the boiler. I want to move the boiler into another room, do I have to reline the chimney or is there another way I can house the flue outside through the walls. In other words do I have to use the chimney for the flue or is there another way?? I hope this makes sense
Any advice would be appreciated
Miss Ron x
missron is offline   Reply With Quote
Old 01-11-2010, 12:25 PM   #2
joed's Avatar
Rewards Points: 11,500
Sounds like your chimney is leaking. Very bad situation. You could get gassed or a fire could start.
Get some CO detectors and have the chimney inpected by a professional ASAP.
Old 01-11-2010, 01:02 PM   #3
Sticky tar!
Thanks Joed, I will get someone out to look at it soon as!!
Who would I look for in the yellow pages, any idea??
Cheers
Old 01-11-2010, 03:16 PM   #4
Rewards Points: 582
Cheers
For an oil boiler get someone who is OFTEC registered.
You may find that the problems with the staining continues as the plaster will probably contain hygroscopic salts. Only hacking off and rendering with added salt retarder will stop this.
stuart45 is offline   Reply With Quote
Tags
boiler , chimney , flue , oli
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 07:09 PM
painting and wallpaper residue jayoshi Painting 1 09-13-2009 06:03 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 12:23 PM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 04:12 PM
