Old 09-20-2012, 07:16 PM   #1
Please help squaring of deck
Im building a floating deck on the dek block system. My depth is 15' 10 1/2" and length is 20' 5". I measured all 4 corners with the 3,4,5 system but the corners do not come out 5' from each point, instead they are 4' 10" at ALL 4 corners. Diagonal to diagonal the measurements are the same too. Is the squaring of my deck fine even if its 4' 10" and not the 5"?
DIY NOOB is offline   Reply With Quote
Old 09-20-2012, 07:24 PM   #2
Framing Contractor
The only way that is possible is that if all of the sides are bowed inward.
sixeightten is online now   Reply With Quote
The Following 2 Users Say Thank You to sixeightten For This Useful Post:
DIY NOOB (09-20-2012), kwikfishron (09-20-2012)
Old 09-20-2012, 07:39 PM   #3
Moderator
kwikfishron's Avatar
If the diagonal measurements are the same then it’s square. Pull a string line between the corners for a reference to straighten out the rest.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 09-20-2012, 08:29 PM   #4
Ahhhhh.....didnt think of that. Id show a pic but the upload fails everytime. No joists are set inside frame yet, just the outer frame set on blocks. I went to look after you mentioned and it was bowing on the 15' 10 1/2" side. Pulled it out some and gave me an inch more. Only checked that side (as its dark out and will finish tomorrow) but im sure once joists are set it will set everything right. Thank you!
foundation walls to support a deck bubbler Building & Construction 1 04-12-2012 04:27 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 12:36 PM
Deck Staining Nightmare steven994 Painting 2 06-17-2010 08:21 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
