Please Help! Sagging Patio Roof.. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-30-2011, 04:58 AM   #1
Please Help! Sagging patio roof..
Last year, I purchased a home that has a covered patio.. The cover consists of a lean-to, and it's sagging about 1" or so over a 12 1/2 ft span.
The roof pitch is right at 1/12.. so, it's pretty flat.
The span is 12.5ft, from where it attaches to the house, to the header. The span is composed of 2x6 pressure treated pine (not sure what grade), on 16" centers.
The cover is 15ft wide, with (3) 4x6 posts supporting the load. They are 7.5ft apart, and have double 2x6's nailed/glued together as the header. There is no evidence of sagging with the header.
The roof is 15x32's plywood, with a layer of tar paper, and shingles on top of that.
Everything that I've read, says that 2x6 pine should be fine for this on 16" centers with a span of 12ft. Why is this thing sagging so much? It's only 2 years old.
More importantly.. what can I do to fix the problem? I'd like to close the patio in, and put a ceiling in place, so going with 2x8's or bigger is out of the question. There simply isn't enough room overhead. Can I jack up the roof with bottle jacks, and nail/glue another 2x6 onto each existing one? Will this be enough support? Should I use a different type of wood?
Any help would be appreciated.. I don't know a great deal about the math involved.. but, I am capable of using a saw, hammer, and a nail gun.
Travis
Trav4011 is offline   Reply With Quote
Old 04-30-2011, 05:20 AM   #2
Here's a simple pic to show what I'm talking about..
Old 04-30-2011, 05:41 AM   #3
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
What part of the country do you live in?
Snow?
Is the sagging point just in the middle where the circle is, so the two rakes are okay?
If so, you may be able to jack that area up and sister on a couple more rafters.
tcleve4911 is offline   Reply With Quote
Old 04-30-2011, 08:45 AM   #4
mem
Rewards Points: 156
I agree with cleve. I would also put on an appropriate roof covering for that 1 in 12 pitch. Shingles are not designed to work on a nearly flat roof. I wouldn't be surprised if you find out that wood up there is waterlogged, adding a considerable amount of weight, compounding the sagging issue.
mem is offline   Reply With Quote
Old 04-30-2011, 01:05 PM   #5
Sorry.. Forgot about the location.. I'm in South Louisiana, so snow isn't a factor.
I considered the same for the singles, but the wood is bone dry. It looks like they used some sort of sealant as they laid the shingles down (not just the sealant strip on the single itself). Also, it hasn't rained here in over a month, so things are nice and crispy.
The roof sags all the way across.. The rake is the portion that hangs over past the header, right? If so, that is fine. It's only 12" or so.
I thought about using (3) 2x6's in the center, glued/screwed together, where it rests directly on the middle 4x6 post. Then, double up the others. Would this be adequate? What type of lumber should I use?
Travis
Old 04-30-2011, 09:48 PM   #6
Guess I'm going to try double 2x6's, glued and screwed together, with a strip of plywood between them. I'll do that every other 2x6, and see how that works out.
Travis
Old 05-01-2011, 12:18 PM   #7
mem
Rewards Points: 156
Originally Posted by Trav4011 View Post
...the wood is bone dry. It looks like they used some sort of sealant as they laid the shingles down (not just the sealant strip on the single itself). Also, it hasn't rained here in over a month, so things are nice and crispy.
Check it after a good rain and see if it is still dry. If it sagged after getting wet, it won't go back after it dries. A continuous bead of sealant across the shingles prevents any moisture that may get underneath from escaping.
The rakes run from the house to the header-the slanted part on the sides. What you describe is the eave--the lowest part of the roof. So the rakes are sagging too?
One would think 2x6 rafters would be adequate across a 12.5 foot span supporting nothing but a roof. Shingling a 1/12 pitch, on the other hand, is a fool's errand. Sistering the rafters would certainly not hurt anything, check the new rafters for a crown and put the proud side up. If there is another reason it's sagging, that is not addressed, it will probably sag again in a few years. Just my opinion.
Post some pics of the rakes, eave, underside and top--perhaps someone here can see what's going on.
Old 05-01-2011, 01:14 PM   #8
Thanks for the advice..
I'll put a pair of water hoses/sprinklers up there today, and hit it for an hour or so. I've checked it before though, after a good/heavy rain, and the plywood is bone dry. The underside isn't closed in, so it's easy to see/get to.
If it IS getting moisture under the shingles, and I decide to remove them. What's the best/lightest thing I can put up there to cover the plywood, that doesn't look like crap?
The rakes are sagging as well.. but, not quite as much, because the 2x6's are doubled up on the outer posts, so it's beefier there. They might be sagging 1/4" or so.. which should be acceptable, right?
Thanks again..
Travis
Old 05-01-2011, 02:20 PM   #9
kwikfishron's Avatar
Rewards Points: 368
Maybe some bonehead crowned them upside down. Wouldn’t be the first time.
How about posting some pictures.
kwikfishron is offline   Reply With Quote
Old 05-01-2011, 11:01 PM   #10
Yeah, but ALL of them? lol..
I'll take some pics tomorrow. I went to Home Depot today, and got some 2x6's, plywood, and Liquid Nails, so I can make a few beams.
Old 05-01-2011, 11:58 PM   #11
Registered User
Rewards Points: 5,482
Be sure to use hot-dipped galvanized or stainless steel fasteners. Check the lumber stamp on the side for the grade number, #3 only span 10'1" with 20# dead load, 11'8" w.10#D.L.; R802.5.1(1): http://publicecodes.citation.com/ico...002_par023.htm
Gary
Old 05-02-2011, 12:01 AM   #12
Gary
Gary,
If I use double 2x6's, with a piece of ply between them, glued/screwed together, I should be good to go?
Old 05-02-2011, 03:52 PM   #13
SteelToes's Avatar
Rewards Points: 150
15/32" 3 ply ..I'd say that's to thin for 1/12' slope ...especially because you would want to cover that up with a torch down ...right ? Shingles are out of the question ...gotta be min of 2/12 slope for the shingles.
It's sagging beacuse they used PT lumber ..they probably framed it when was wet...so it settled down ..It never goes up.
SteelToes is offline   Reply With Quote
Old 05-02-2011, 06:32 PM   #14
I hit it with sprinklers for 2 hours yesterday.. It's was bone dry. I even went as far as to spray a heavy stream of water in one spot (right at a plywood seam), from a foot away, for about a minute straight, and it didn't leak. Even if it DID leak past the shingles, how would it get past the tar paper?
The wood is pressure treated, as I stated in my first post. It is number 2 choice PT pine. I'm not sure if it was wet when they framed it or not.
Tearing it apart isn't an option. I WILL make it go back straight, whether that requires the use of laminated beams, or steel I-beams. One way or another, it will straighten out.
Old 05-02-2011, 06:40 PM   #15
Framing Contractor
Rewards Points: 118
Maybe it was built with the sag. Run a string across near where it si attached to the house to see if the sag is present there as well.
sixeightten is offline   Reply With Quote
Sagging roof Haney1 Roofing/Siding 23 10-23-2012 10:04 AM
Sagging puddling flat roof Jon S. Roofing/Siding 2 12-07-2009 06:59 PM
fix a sagging roof ridge...?? red86yota Building & Construction 2 02-06-2009 08:46 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
roof relly sagging farmer7 Roofing/Siding 7 10-22-2007 09:37 PM
