Old 01-18-2011, 03:41 AM   #1
Please help!! Old brick house
I just bought a house that needs remodeling. My fiance and I have figured out what we wanna do to the inside, but we are at a complete loss for how to improve the appearance of the outside. Its a very dark brown shade of brick. I would be willing to do a whitewash or stain the brick, but prefer not to paint it. I would like any suggestions to improve the curb appeal not just advice on the brick, thanks!!
brandi_lea is offline   Reply With Quote
Old 01-18-2011, 03:45 AM   #2
I just bought a house that needs remodeling. My fiance and I have figured out what we wanna do to the inside, but we are at a complete loss for how to improve the appearance of the outside. Its a very dark brown shade of brick. I would be willing to do a whitewash or stain the brick, but prefer not to paint it. I'm also interested in an inexpensive way to change the roof to look a little... I would like any suggestions to improve the curb appeal, thanks!!
Old 01-18-2011, 06:17 AM   #3
RFN-4A-LVN
Roofmaster417's Avatar
You roof makes up at least 65% of your curb appeal.You can have your roof cleaned provided your contractor of choice is experienced with proper technique.,I do not recommend a first time DIY'r to dive into this procedure because it can get ugly quick.How many layers are on your roof? What is the approx.time has your roof been on your home? Take a few pix of the front and sides and rear of your home and post them.Many people/contractors are here to help you along the way.
Roofmaster417 is offline   Reply With Quote
The Following User Says Thank You to Roofmaster417 For This Useful Post:
brandi_lea (01-18-2011)
Old 01-18-2011, 06:26 AM   #4
jmiller is offline   Reply With Quote
Old 01-18-2011, 10:45 AM   #5
I would try other improvements before messing around with the brick. You could try new shutters, or a front patio, or paint the trim, or some new gardens or plantings, or even train a vine to grow up the bricks. You could also change out the supports on the overhang, get rid of the screen door and get a nice new front door. There are a lot of possibilities. This could be a very cute home.
Windows is offline   Reply With Quote
Old 01-18-2011, 11:26 AM   #6
[IMG][/IMG]Here is a picture, any suggestions would be a great help! Thanks
Old 01-18-2011, 11:57 AM   #7
Matthewt1970's Avatar
That is pretty much exactly what I would suggest. Leave the brick alone.
Old 01-18-2011, 11:59 AM   #8
I would re-do the porch in your favorite porch style. Supports and a railing, and then do something with the yard.
I'd leave the brick alone. The dark color will make the lighter color trim things pop.
michaelcherr is offline   Reply With Quote
Old 01-18-2011, 12:15 PM   #9
Experienced
Jackofall1's Avatar
I would leave the brick alone
Clean-up the garden on the left of the porch
Change the over hang supports and add a nice railing
Ditch or paint the shutters
Add a garden infront of the porch
Clean-up the yard and try and get some grass growing, looks like sand base, Florida?, you'll need lots of water, lots and lots to keep the grass growing.
Old 01-18-2011, 02:04 PM   #10
A Little Of Everything
Add 1 more vote for "leave the brick alone."
You have TONS of things to do to the house, and the yard, to improve its look and curb appeal. Do those things first.
DrHicks is offline   Reply With Quote
Old 01-18-2011, 03:19 PM   #11
I once saw a dramatic transformation in the look of a house when the bricks were stucco'ed. Applying layers of stucco changes the look; binds all the brick together making for a solid mass; and makes them waterproof. The stucco binds directly to the brick and mortar joints. You can use a masonry paint to paint the house (a lighter shade) or apply a thin synthetic stucco layer with coloring. You will want to check with your local code restrictions.
woody9911 is offline   Reply With Quote
Old 01-18-2011, 03:40 PM   #12
Tom Struble's Avatar
lots you can do,i personally wouldn't coat the brick,try gently cleaning it,it may brighten up,re paint the trim,new front door change out the porch columns,new shutters,add a nice walkway and some landscaping
Tom Struble is offline   Reply With Quote
Old 01-18-2011, 04:09 PM   #13
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
Absolutely! Just clean the brick. Perhaps a new,fairly small, gabled entry way with a couple appropriate columns to sort of reach out and invite one in.
With two short walls leading back to the house of the same brick and a concrete cap.
Not a huge expense but would look great.
New paint on the painted area and landscaping and voila.
Andy.
AndyGump is offline   Reply With Quote
Old 01-18-2011, 04:20 PM   #14
gabled entrance... yes nice Andy
The Following User Says Thank You to Tom Struble For This Useful Post:
AndyGump (01-18-2011)
Old 01-18-2011, 06:14 PM   #15
Thanks for all the input...It's hard to see anything helping that brick. Its so dark it almost looks black. Should I change the roof color? Any and all suggestions are much appreciated!
Chimney leaking AgentW Building & Construction 43 12-23-2010 11:20 PM
Brick house foundation question. Nickcc1086 Building & Construction 9 08-21-2010 05:47 AM
Moisture concerns with adding framing to old brick house Stemboat Building & Construction 2 07-15-2010 10:04 PM
Closing in exterior doorway on brick house laur6162 Building & Construction 5 08-23-2009 06:19 PM
Interior insulation of an old brick house 29er Remodeling 3 03-10-2009 07:08 PM
