Please Help With My Existing Deck - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-09-2012, 10:18 AM   #16
Bill Kearney
Rewards Points: 1,174
The only thing I could see doing would be to put new 6 new 6x6 columns under it with new joists. Support the corners (both outside AND at the house) and then in the middle. Essentially putting a frame under what's already there. The outside posts could be replaced to allow re-using their position. This might entail pouring new footings, to say nothing of getting the old ones out. The deck would have to be supported temporarily, of course. But with this frame you'd lose the headroom underneath of it.
You don't want to hear it but you're going to be far better off taking that deck down and putting up a new one that's done properly. Don't know that it'd be practical to keep the roof while replacing the deck, probably not.
wkearney99 is offline   Reply With Quote
Old 06-09-2012, 01:30 PM   #17
GBrackins's Avatar
Rewards Points: 2,108
piper,
how much room is there above the ground level slider and the bottom of the existing deck floor joists?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 06-09-2012, 02:50 PM   #18
Originally Posted by danpik View Post
This is the part that bothers me the most. All of the weight of that deck is resting on the two framing members at each end of the deck. All of that weight is then transfered to the connection points at either end of it. If this is truly the case then adding joist hangers won't do anything.
Im surprised no one else has mentioned this. Im no structural engineer, but If the joists are parrallel to the house then half the weight of that deck is only supported by 2 points along the entire length of the deck along the house. There no pics or details of how those two points are attached to the house
Eds_tls is offline   Reply With Quote
Old 06-09-2012, 03:28 PM   #19
GBrackins's Avatar
you are correct! that connection (end framing member connecting to dwelling) has about 2,000 lbs of load.
If it was my deck I would not use it until corrected.
there are viable solutions, but only after more photos and answers to questions are provided.
Gary
Old 06-12-2012, 12:22 PM   #20
Rewards Points: 29
In all fairness, I would remove it and start over!
spinfisher is offline   Reply With Quote
Old 06-12-2012, 04:07 PM   #21
GBrackins's Avatar
May be quicker and cheaper to do so
Gary
Old 06-12-2012, 04:53 PM   #22
Rewards Points: 150
I would concur. It will be cheaper and safer to start from scratch.
If the AWC wanted to build a project to show all the ways not to build a deck I don't think they could have done a better job.
goosebarry is offline   Reply With Quote
Old 07-13-2012, 06:10 PM   #23
Thanks Everyone
I apologize for my long absence. The deck didn't fall and kill me (or anyone else)!! Just fixed up the deck, had the baby's first birthday, went on a little vacation, then been working like a madman. I did consider tearing down the whole thing, but I decided against it. I have built a frame out of 4x4 posts and 4x6 cross beam placing them 3 ft in from each end. I have also doubled up the outside band, reduced the joist spacing to 12" on center, and tied everything together with hangers, ties, and new fasteners. Future plans include replacing the old 4x4 posts with new posts, getting everything painted up, adding another post support for the stairs, then replacing the 4x4 post holding the roof up. I will post pics in the next day or so. Thanks again everyone!
Also, an answer to a question or two that was asked. There is about 6 inches above the slider and the bottom of the deck. I don't know how the ledger is attached to the house, as the inside of the basement is completely finished in. That's another reason I decide to bring frames in under the deck to relieve the weight on that ledger.
piper131 is offline   Reply With Quote
Old 07-13-2012, 06:21 PM   #24
About 6" above the door, to the bottom of joist.
Deck stairs over existing stone retaining wall steps joshg3p0 Building & Construction 16 05-02-2012 11:30 PM
Yankee gutter resurfacing options miamicuse Roofing/Siding 24 01-06-2012 08:20 AM
possible gazebo off my existing deck rollinastang Carpentry 3 05-23-2011 03:52 PM
Install Flashing onto existing deck ledger, stucco home Ameekins Building & Construction 1 09-15-2010 05:51 PM
Extend existing deck dknarnd Building & Construction 1 04-25-2010 08:09 AM
