Please Check Out And Rate This Window Replacement Job... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-04-2009, 02:21 PM   #1
dsq
Please check out and rate this window replacement job...
Hi,
I have put up some pics of some work that was done and would like to see what your opinion of this work is http://dunk222.angelfire.com/window_...m/june_035?i=0
Somebody i know had their windows and patio doors replaced.
I say it looks unfinished,unprofessional and not properly done.
Many of the windows and their frames look too small as they are not flush with the wall-the installer didnt take out the old frames they just screwed in the new windows on top of the old frames.You can see screw exposed attaching the new window frames to the wall and you can see the old frames!!!
There are a couple of windows where the installer made new wood frames out of 2x4 and they are flush with the gyprok.Is this correct?It looks ugly and we have to now put trim/moulding to cover it.Shouldnt these 2x4s been set back in the wall so we could have patched area with drywall to make it flush with the rest of wall?.
The patio doors frames are flush with the stucco.There appeaars to be cracks and they did some filling in with caulk etc...
dsq is offline   Reply With Quote
Old 06-04-2009, 02:35 PM   #2
Welcome to the wonderful world of direct from the factory window installations. Why do you even ask.
hayewe farm is offline   Reply With Quote
Old 06-04-2009, 02:41 PM   #3
dsq
I ask because i dont know if that is the way its supposed to look-it looks sht to me.I also want to know if this is the installers fault or if this is the best it can look with vinyl windows.
Old 06-04-2009, 02:53 PM   #4
In my opinion, they are not sized correctly, they are not installed properly, and the are the wrong windows for this situation. But then again maybe I'm just picky.
Old 06-04-2009, 02:57 PM   #5
dsq
When you say not sized properly are you are saying that the vinyl frames should come flush to the walls from the get go and you should not see screws exposed?
Old 06-04-2009, 03:02 PM   #6
joed's Avatar
Rewards Points: 11,964
You should definitely NOT see the screws.
Old 06-04-2009, 03:02 PM   #7
Rewards Points: 5,336
What would you expect from the Ray Charles Window Co.?
It looked good to him.
Ron
Old 06-04-2009, 03:28 PM   #8
Newbie Bill
Rewards Points: 520
I agree that those look awful, and now I am worried.
We are in the process of getting quotes to get some new windows installed. I decided to go direct to the manufacturer and was going to have their crews install the windows. Are you guys implying that this isn't the way to go? I figured it was better than picking a name out of the yellow pages.
Suggestions?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 06-04-2009, 03:41 PM   #9
Manufacturers are in business to sell their windows right or wrong. If a lousy job is done installing they can divert complaints by saying the fired the drunks that did the installation. If their reputation is bad they just change the name of the company and start all over. A contractor has to depend on referrals to stay in business, his name is what the reputation is built on. He has the choice of different manufacturers and will work to choose the proper style for the job.
Old 06-04-2009, 04:01 PM   #10
SNC
Well I think the inside can be trimed out with 3/4 wood and look ok
SNC is offline   Reply With Quote
Old 06-04-2009, 04:52 PM   #11
Rewards Points: 1,016
The pictures are those of an incredibly bad replacement window installation... I have vinyl replacement windows that fit and look great.
Old 06-04-2009, 06:22 PM   #12
Registered User
Rewards Points: 5,204
I noticed the weep holes at one window's bottom, but couldn't see any others. Could you take a picture of only the bottoms of the fixed units? Poor installation. Be safe, G
Old 06-04-2009, 08:10 PM   #13
So when are they going to finish?
Old 06-04-2009, 08:25 PM   #14
Tom Struble's Avatar
Rewards Points: 2,002
in stucco too,perfect
Tom Struble is offline   Reply With Quote
Old 06-04-2009, 09:32 PM   #15
My primary concern would be improper flashing behind and around the replacement windows - especially in stucco. My understanding of window installs with stucco exterior (based on heresay, not on first hand experience) is that it is more difficult because the stucco must be cut back to allow proper taping and flashing, then the replacement stucco must be properly re-applied and blended to the remaining original stucco. Our neghbors have elected to retain their original windows (circa 1982) because the cost of a contractor skilled in this type of install was prohibitive.
Obviously the harm in deficient flashing is the eventual intrusion of water in the wall cavity and subsequent mold / decay potential
rizzo is offline   Reply With Quote
