I've built a pirateship playhouse and opted to use decking as the siding (to look more shiplike) and did not use any plywood sheathing underneath. It seems rigid enough at first, but now that the wood has dried out, the framing has a lot a lateral movement. I'm hoping for ideas that avoid removing the siding boards and adding plywood sheathing. The cabin is a basic 4 x 6 playhouse framing set up (plus a bow section, unattached to the cabin framing).
I'm a beginner builder, so hopefully someone has some ideas that I'm not aware of, so that I don't just go our there and start adding 2x4s and hoping that will solve it...
Did you use 2, screws anyplace the deck boards came in contact with the 2 X 4's?
Those 2 X 2 balisters also need to go you have the rope attached to and be replaced with a 2 X 4's.
Hi, add a few more studs ( 2x4) in the walls and put two screws into the studs at each deck board where they cross the studd. this should provide lateral stability. shoot for 12" centers for the studs and there probably will not be much movement after that.
Plywood on the inside, remove siding and plywood on outside then reinstall siding,
Or diagonal boards on inside. Not just one as a brace but entirely cover. As stated above.
In the long run you may find that a few more studs with 2 screws in each board will not work
very nice i love the concept and design :thumbup:
a little movement would not concern me as other said
if there is more than you like i would suggest adding diagonal 2x between existing 2x wall framing then put 2 screws through each deck board into new diagonal 2x framing. i would not suggest enclosing inside for strength due to you have then caused a nice shelter for wasps, bees and other insects which could get through spaces between deck boards
Thanks for the input everyone. I doubled up my screws into the 2x4s and that helped enough. If the kids wind up climbing it, I'll probably add the diagonal braces.
Looks really cool. I like the idea. I may try building one in back yard. Thanks boogie81
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
