Old 09-02-2009, 09:28 PM   #1
Plastic sheets for siding
I am using 4 x 8 sheets of 1/8" thick FRP (fiber reinforced plastic) for a 12 foot by 6 foot smooth walled section. It has 1/4" thick 2" wide strips glued to it every 2 feet for architectural detail. In any event I just nailed it up to plywood with nails 8" on center and it looks wavy. Perhaps it expanded more than the plywood. I was thinking of gluing it directly to the plywood using polyurethane construction adhesive. It is siding for a gable peak and has the attic behind the plywood so moisture flow is not too much of an issue. The alternative is to tear it out and rebuild it using MDO. That's alternative is a lot of work. Thanks.
PerpetuallyRepairing is offline   Reply With Quote
Old 09-02-2009, 10:12 PM   #2
Moderator
Termite's Avatar
FRP is normally used in commercial kitchens and bathrooms...Places where it can be adhered to the wall substrate. It is nice because it will clean up easily. One thing it is not is an exterior siding material. I don't think it'll ever look right in this application for you.
Old 09-03-2009, 11:05 AM   #3
It is nice to hear it is adhered in indoor applications. Perhaps that is the route to go. Azek makes 1/8" thick 4'x8' sheets of PVC so I don't think its too much of a stretch to do what I did.
Old 09-03-2009, 10:02 PM   #4
Tom Struble's Avatar
yea i dont think just nailing it is going to work
thin plastic materials transfer any waviness
you gotta get your substrate flat and use the approved glue
for the frp,ive always seen it installed with contact cement
but construction adhesive might work fine
as long as its recommended by the panel manufacturer
Tom Struble is offline   Reply With Quote
Blue plastic receptical/switch boxes used as junction boxes? alexz Electrical 7 04-09-2013 09:40 PM
Lay plastic between ground and concrete slab? Flt_Simulation Flooring 8 04-22-2012 06:56 AM
Plastic instead of metal... hvaclover Electrical 11 11-13-2008 10:07 AM
What do you think about Double Glazing with plastic sheets? foster01 General Discussion 1 08-25-2008 05:12 PM
Corrugated plastic fixtures tonydee Roofing 4 07-16-2008 11:36 PM
