Old 12-27-2006, 01:20 PM   #1
yummy mummy's Avatar
plastic or metal boxes for outlet wiring?
Should I purchase plastic or metal boxes to add a new receptacle?
I have a book and it tells me to go with plastic as opposed to metal.
It states that metal is for commercial and outdoor use.
I will be attaching it to the wall studs and then insulating?
thanks
yummy mummy is offline   Reply With Quote
Old 12-27-2006, 06:44 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Use plastic
- Build Well -
Old 12-27-2006, 07:29 PM   #3
thanks atlantic
Old 12-30-2006, 02:02 AM   #4
Metal boxes are fine and used in residential as well as commercial.
They are however recommended for outside walls being sealed and provide an easier means to draft proofing and rust prevention should you encounter moisture.
For a few bucks more it just to give you a simple 'slap it on' rather than having to install vapour barrier completely 'around' a metal box.
Instead, you simply v/b over and cut the face opening and your done.
-Greg
smokumchevy is offline   Reply With Quote
Old 12-30-2006, 04:05 PM   #5
The boxes are for the outside perimeter walls (2X4 studs) and then I will insulate and vapor barrier over.
I assume I can go for either one.
When my house was built 3 yrs ago. metal was used.
I assume I can do either?
thanks
Old 12-30-2006, 04:32 PM   #6
remodeling pro
thanks
Metal is not necessiraly for commercial use, it was used for both until fairly recently when first fiberglass, then plastic or rubber took over the residential area, because they are cheaper to purchase and less labor intensive to install since each box itself does not have to be grounded.
troubleseeker is offline   Reply With Quote
Old 12-30-2006, 10:37 PM   #7
thanks for the additional information.
I may try both
Old 12-31-2006, 04:01 AM   #8
Sorry, after re-reading my post I made it confusing. I meant to say 'the plastic boxes, however, are recommended for outside walls etc etc' .
note: you still have to ground inside the plastic boxes as well as the outlet because the ground screw in there grounds the strap for when say a switch (that normally doesnt have a groundscrew) is used.
Old 12-31-2006, 08:33 AM   #9
Yummy, do not bother using metal, use plastic.
- Build Well -
Old 12-31-2006, 02:37 PM   #10
Because I respect your advice and hold you in high regard, I will go with plastic.
Thanks Atlantic and everyone for their advice.
Blue plastic receptical/switch boxes used as junction boxes? alexz Electrical 7 04-09-2013 09:40 PM
Plastic vs metal switch boxes tropic home Electrical 1 11-29-2006 06:54 PM
Proper ground with plastic boxes tjandt Electrical 3 11-07-2005 09:16 AM
