Plastic To Concrete Adhesive Advice! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-22-2008, 05:20 PM   #1
Beer Advocate
Taipans's Avatar
Rewards Points: 150
Plastic to Concrete Adhesive advice!
So if I go ahead and put plastic over my basement parameter drain gap to keep the vapor from rising up. What kind of adhesive do you guys reccomend to use? Not sure what is good to stick concrete / plastic together and be waterproof!
Taipans is offline   Reply With Quote
Old 02-22-2008, 07:02 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
any kindd of Urethane or Polyurethane sealant.
- Build Well -
Old 02-22-2008, 07:12 PM   #3
PL Premium will bond most anything together.
jerryh3 is offline   Reply With Quote
Old 02-22-2008, 07:26 PM   #4
Beer Advocate
Taipans's Avatar
Rewards Points: 150
Thanks!
Old 02-23-2008, 08:51 PM   #5
Crabby Bastard
terri_and_jj's Avatar
don't stick it, shoot it
get one of those powder actuated tools ( Hilti, Ramset, Remington, etc.) and some short washered pins. These tools are readily available and pretty handy. the guns range in price from $20 - $800 but the pins and loads are pretty cheap. just make sure to take care and follow directions
terri_and_jj is offline   Reply With Quote
Old 02-24-2008, 12:10 AM   #6
Beer Advocate
Taipans's Avatar
Rewards Points: 150
For plastic to concrete?
I am using Tapcon screws for the studs / floor, I wouldn't even really consider glueing them down. *shrug*
Old 02-24-2008, 09:21 AM   #7
Crabby Bastard
yes, shooting plastic to concrete works GREAT, as long as you are using washered pins. Half the price of tapcons and ten times faster
Old 02-24-2008, 02:28 PM   #8
Installing Poly by using a powder actuated fastener is total overkill and a complete waste of money...
- Build Well -
Old 02-24-2008, 07:17 PM   #9
Crabby Bastard
i don't know where you buy your tapcons, but powder pins and loads are usually about the same price as tapcons and with my semi auto hilti gun i can shoot 10 pins faster than i can drill a pilot hole and install a single tapcon
is it overkill, sure, but i think if you look at installed cost you will see its the pretty cost effective, even if you are a weekend warrior who is not paying for labor
Old 02-24-2008, 08:03 PM   #10
Still overkill.....Never seen anyone (company, person, no-one) install poly with tapcons or pins.
- Build Well -
Old 02-25-2008, 06:33 AM   #11
Beer Advocate
Taipans's Avatar
Rewards Points: 150
Since I am trying to seal the drain itself so air doesn't rise out and condense I can't see washers making an air tight seal along the entire wall anyhow.
Old 02-25-2008, 07:10 AM   #12
Putting holes in the poly will affect the "barrier" portion of the concept.
That suggestion to use fasteners, quite honestly (I'm sorry to say this), is ridiculous.
The standard moisture, or wateproofing applications, for sealing any concrete or masonry surface is always, using a "spray-on" or "rolled-on" applied - MR material. I just spec'd a Waste Water Treatment Building, that had CMU walls (Cinder blocks). The plans called for an application of water proof spray over the exterior masonry walls, prior to attaching PT stock, foam, sheathing, and vinyl siding. - Not poly.
- Build Well -
Old 02-25-2008, 07:42 AM   #13
Beer Advocate
Taipans's Avatar
Rewards Points: 150
I used a Polyurethane adhesive / sealent like you guys reccomended. It was in a caulk form, but since I was just sealing over a 1inch gap I figured a good bead on top and bottom should work out. For the actual vapor barrier I am going to use 4 - 6 mil poly and staple it over the 2x4s.
Thanks for the help!
Old 04-27-2011, 09:55 AM   #14
Hey all- I am trying to glue some of the new plastic styrofoam used in packing boxes to painted concrete wall. Have had little success.
pamtedd is offline   Reply With Quote
Cleaning adhesive from a concrete subfloor sparinaa Flooring 3 09-07-2011 01:11 AM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
need advice befor pouring concrete in barn abtankerman General DIY Discussions 4 11-03-2007 05:59 PM
Painting concrete w/cutback adhesive on it Mikon Painting 3 10-16-2007 09:27 PM
Adhesive removal from concrete sod Flooring 3 04-02-2007 09:41 PM
