Plastic Cap Nails - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-04-2014, 08:53 AM   #1
Rewards Points: 240
plastic cap nails
is it possible to buy just the plastic caps ?
Fix'n it is offline   Reply With Quote
Old 10-04-2014, 09:02 AM   #2
AHH, SPANS!!!
Rewards Points: 1,166
you'd have to get the nails and remove the nail. I've used the plastic caps for shims and what not over the years
hand drive is offline   Reply With Quote
Old 10-04-2014, 09:05 AM   #3
Rewards Points: 240
my aim is to save a buck. these are pretty expensive per box. and i already have plenty of nails. i see now that there are caps on a roll. but that could be expensive also. idk.
Old 10-04-2014, 09:24 AM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,328
no you cant. their pricey because their a specialized fastener for putting on house wrap and rigid foam.. if your putting on housewrap roofing nails also work, similarly for foam siding nails also hold provided you nail into the studs. the only thing is depending on the region some areas require cap nails by code for applying either
woodworkbykirk is offline   Reply With Quote
Old 10-04-2014, 09:56 AM   #5
Rewards Points: 144
Don't feel bad.I use cap staplers for roofing and house wrap.They are $92 a box.
mako1 is offline   Reply With Quote
Old 10-05-2014, 08:40 AM   #6
Rewards Points: 240
well, i guess i will just have to pay up.
Old 10-05-2014, 06:22 PM   #7
Rewards Points: 526
In the OLD days I used to buy boxes of the little metal circles which I then fastened with a roofing nail. Times change? Ron
ront02769 is online now   Reply With Quote
Old 10-05-2014, 08:38 PM   #8
Rewards Points: 181
Putting up polyiso? Getting cold out huh?
Flooring Installer. Ecological Restoration Technician. Green Building Enthusiast. Obsessed with insulating and air sealing.
wewantutopia is offline   Reply With Quote
Old 10-05-2014, 08:52 PM   #9
Remodeler
Rewards Points: 330
Try this
or you could buy just the caps for the bostitch cap stapler, actually cheaper since you get 500 more for just a bit more money.
Not sure if either would actually save money, I don't use cap nails since I have the cap stapler.
iamrfixit is online now   Reply With Quote
The Following User Says Thank You to iamrfixit For This Useful Post:
Fix'n it (10-05-2014)
Old 10-05-2014, 09:42 PM   #10
Rewards Points: 240
thanx ! added them to my cart. i don't need 1000
Old 10-05-2014, 09:43 PM   #11
Rewards Points: 240
1" XPS. today was'nt bad.
Old 10-06-2014, 10:22 AM   #12
Rewards Points: 126
yes, you can
jack45870 is offline   Reply With Quote
Rough Framing / Too Many Nails? powertoolguy Building & Construction 17 08-21-2014 10:12 PM
Nails? Nails? Nails?! gunns General DIY Discussions 18 03-06-2014 11:25 AM
33 vs 35 Nails Dilemma banzaitoyota Tools 1 12-28-2010 06:44 AM
Plastic - using plastic to make your own replacement parts Hemingway General DIY Discussions 5 09-26-2009 07:49 AM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 10:31 PM
