Plastering A Room - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-15-2009, 10:45 PM   #1
plastering a room
I am going to attempt to plaster a room in my house and am unsure if using the same plaster for both base coat and top coat is the proper way to do this, or if there is a different composition for each coat. I am planning on using USG Diamond brand.Any advice would be appreciated.
herewego is offline   Reply With Quote
Old 04-15-2009, 11:14 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
they are different mixtures.
http://www.usg.com/navigate.do?resou...at_Plaster.htm
http://www.usg.com/navigate.do?resou...sh_Plaster.htm
Old 04-16-2009, 03:19 AM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
You are in over your head if you have never heard of scratch coat or brown coat.
http://www.do-it-yourself-help.com/t...t_plaster.html
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-23-2009, 11:43 PM   #4
I guess I should have mentioned that I am plastering on new blueboard. Thanks for your input.
Old 04-24-2009, 12:04 AM   #5
Residential Contractor
My plasterers will not use Diamond base, their method of choice is Imperial Basecoat and Diamond Finish w/ a little retarder to slow it down some. The Diamond Base has proven to be fairly inconsistant setting time wise. One piece of advice from me and I am a proficient hawk and trowel taper, Veneer plaster is a PITA to learn, timing is everything with it, Build a couple of Mock walls and practice there until you think you have it down and then some more for safety, because once it goes off you re stuck there is no going back, to tear it off you replace the Blueboard too!!! On your finish, lay it on about an 1/8-3/16"smooth , once it starts to set get your pool trowel out and some water and slick it out from there. Remember you cant sand it so watch out and good luck.
Trace
P.S.
Remember to start in a corner and finish the whole wall it has a tendency to flash through paint if you stop mid panel.
Tracymc is offline   Reply With Quote
Old 04-24-2009, 06:13 AM   #6
Rewards Points: 5,336
Take some before and after pictures. and post what you learned about the project.
Ron
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 07:28 PM
A room in a room? artosie General DIY Discussions 2 03-10-2009 12:43 PM
Cold Room mikelbeck HVAC 14 01-16-2009 08:21 PM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 02:51 PM
