Plastering Mix - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-26-2007, 05:24 AM   #1
Plastering Mix
Could anyone please tell me what the mix is for plastering for a smooth finish on an exterior breeze block wall. I would wondered if it was possible to plaster over a wooden framework with galvanised mesh pinned to the framework. Is there a chance the plaster mix might fall off?
Suzanne
Liamsbab is offline   Reply With Quote
Old 05-26-2007, 07:10 PM   #2
concretemasonry's Avatar
Rewards Points: 2,570
Are you in Great Britain?
That could have a bearing on the selection of materials and practices.
I am not qualified on plastering, but there are others that can offer suggestions.
concretemasonry is online now   Reply With Quote
Old 05-26-2007, 07:16 PM   #3
Hi, I am in the UK.
Thanks for replying
Old 05-29-2007, 06:14 PM   #4
Not quite sure what you are trying to achieve?
If block then there is no need for mesh as the render/stucco will key. Wooden frame?
As for mix & quantities see here: http://www.source4me.co.uk/calculate_render_stucco.htm
marksson is offline   Reply With Quote
Plastering over paneling TNRocks Remodeling 13 01-14-2010 07:47 AM
Plastering help Plaster Brokers Introductions 8 02-01-2009 09:42 PM
plastering nypainter Painting 8 08-13-2007 07:41 PM
plastering or drywall section? Plaster Brokers Site Help and Suggestions 0 07-27-2007 10:26 PM
Plastering on newly laid brickwork? djj66 Building & Construction 10 09-21-2005 01:01 AM
