Plastering - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-18-2005, 12:08 PM   #1
Plastering
I have a section of wall that is down to the brick. I realise that I will have to PVA the brickwork before applying browning, but do I then PVA the browning (once dry) before skimming?
Cheers
imported_Pete is offline   Reply With Quote
Old 08-26-2005, 08:52 AM   #2
hmm, anyone?
Old 08-26-2005, 12:01 PM   #3
I would think that pva the brickwork before would be all that would be needed. If you are only making a repair moisture could still leach from surrounding plaster work though. but I would not think it would do any good to pva again before skimming.
Just my opinion.
Mgmopar
MgMopar is offline   Reply With Quote
Old 08-30-2005, 04:47 AM   #4
Thanks MgMopar. I think I'll go with that advice, cheers.
Old 03-09-2006, 05:11 PM   #5
TEXTURE REVIVAL
Dale's Avatar
Hi Pete,
You Will Need To Pva The Dried Browning, Or Any Other Surface That Will Become Porous Once It Has Dried Out, As You Will Have Found That The Plaster That You Have Put Onto The Dreid Out Bonding Probably Went Off Quick, The Problem With This Is Not That It Dries Too Quickly To Work With It But The Plaster In The Long Run Does Not Bond As It Should Because It Is Drying Too Fast
I Hope That This Helps
Dale
Dale is offline   Reply With Quote
