Plasterboard Wall And Heavy Mirror - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-16-2005, 08:03 AM   #1
Angry
Plasterboard Wall and Heavy Mirror
I have a thin plasterboard wall that I have been trying to fix a heavy mirror to. Problem is......................I can get one self drill plasterboard fixing to fit with the hook type screw supplied with the mirror but the other self drill thing won't take the screw and turns with it then falls out! When I poke through the hole in the wall I can hear plastic, I am assuming this is the cavity insulation. I now have 4 large holes in my flamin wall and am none too happy.
The fixing supplied with the mirror is pretty large about 8mm thick and the thread is around 2cm.
I would appreciate the help as the amount I have spend on fixings I could have built a brick wall!
Cheers!
W
Dax1 is offline   Reply With Quote
Old 08-04-2005, 05:12 PM   #2
Hey W
It almost sound to me the intended this mirror screw to go into a stud. Is the hook supplied with the mirror decretive as well or could you use a different type?
http://www.ehow.com/how_9938_choose-...e-hangers.html
http://www.monkeyhook.com/index.asp
http://www.lowes.com/lowes/lkn?actio...ghtNavHowTo%20
scoll on this one down to "Using Anchor and Toggle Bolts"
Mgmopar
MgMopar is offline   Reply With Quote
