Plaster Walls. Asbestos - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-18-2010, 10:44 AM   #1
Plaster Walls. asbestos
Hi,
Quick question. I am working on painting our living room and noticed that there was a textured paper on the wall. It was painted over some time ago and cracks formed beneath and are showing through.
I was in process of repairing the cracks when I noticed how easily the paper was coming off the walls. Could it be asbestos wrap paper on the walls? Its thin, totally dried out, and flaky. I can post a picture of a piece.
Thanks.
doublea is offline   Reply With Quote
Old 08-18-2010, 12:02 PM   #2
Rewards Points: 5,336
More likely a wallpaper covering to disguise plaster cracks. I've never heard of that paper being made of asbestos. The only real way of telling is to have it tested.
Ron
Old 08-18-2010, 12:04 PM   #3
Ron
Yea I am thinking to send out a sample of the paper. The house was built in 1940. It has standard framing with cement board and plaster on top.
Old 08-18-2010, 12:40 PM   #4
What you have is a mulicoat plaster. There wasn't any cement board in the '40's. The brown coat went over a lath material. It was topped with the white plaster coating.
If you have a decent microscope(or even a magnifying glass, you can identify asbestos by matching it to a picture on the web. Asbestos is easily identifiable.
Ron
Old 08-18-2010, 12:43 PM   #5
Ron
Is it just called brown or is that the color. Because what is behind the wall is a gray layer followed by a white layer. There is definitely no lathe behind my walls (from what I have looked at).
Old 08-18-2010, 01:14 PM   #6
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
It is likely rocklath with traditional 2 coat plaster over it. The rocklath in the 50's and 60's and maybe back into the 40's was a 2x8' or 2x9' by 3/8" thick board that very closely resembles drywall. Now virtually the same product as was used at least in the 60's is sold in 4'x8' sheets, commonly in 1/2" called blueboard or plaster board. It is sold with drywall at all major home improvement stores. As far as I know rocklath or the 2 coat plaster did not contain asbestos, but I don't know that for certain.
The order would have been rocklath, brown coat, finish (white) coat.
Jamie
jamiedolan is offline   Reply With Quote
Repairing Hairline Cracks in Plaster Walls jerome8283 Painting 8 11-17-2011 07:43 AM
Using Schluter-KERDI wall system over plaster walls. ADIAGA Tiling, ceramics, marble 6 08-02-2010 08:56 PM
Paneling Over plaster walls? Mecca421 Remodeling 4 05-27-2010 06:20 PM
How do I clear up black mold on plaster walls? frustratedtnant General DIY Discussions 6 08-14-2009 03:56 PM
Please Help! Wondering if its asbestos in the walls or not T_T gamdore Building & Construction 2 06-14-2009 04:32 PM
